need help wiring aux lights
/ need help wiring aux lights #1
brown1
grass lake mi
bobcat ct235
as anyone wire rear aux light? i see there is a fuse for one, is there a wire ran under seat perhaps or somewhere else or should i just use one of the spare fuse slots and run my own wire? thanks in advance for any help and merry christmas to all.
/ need help wiring aux lights #2
if there's a fuse there's probably a wire...somewhere.
On Kubota's the wire is under the fender by the tail lights and comes on with the key so the light needs a switch.
/ need help wiring aux lights #3
There is a power and ground wire wired in already. Look at right rear corner just below the tool box shelf, there are 2 wires with round "bullet" style plug connectors for rear work lights. Wire is hot, no switch, so you need to add a switch with the lights.
great thank you
i have them wired and have plowed a couple times, works great thanks for the help.
just a el cheapo from tsc but it gets the job doneimage.jpgimage.jpg.. not sure if this will work i am trying to do this from my iphone and im having trouble.
/ need help wiring aux lights #9
Looking good. Thanks for pictures. You just used some heat shrink butt connectors?
there were already butt connectors there so i greased then used them.
/ need help wiring aux lights #12
Actually there called bullet connectors. A butt connector is something you connect 2 bare wires together with.
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
Mini Universal Concrete Bucket (A65640)
Mini Universal...
2025 Ranger 1000 XP Northstar Premium (A62679)
2025 Ranger 1000...
Longhorn Skull (A65583)
Longhorn Skull...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
