need help wiring aux lights
   / need help wiring aux lights #1
brown1
grass lake mi
bobcat ct235
as anyone wire rear aux light? i see there is a fuse for one, is there a wire ran under seat perhaps or somewhere else or should i just use one of the spare fuse slots and run my own wire? thanks in advance for any help and merry christmas to all.
   / need help wiring aux lights #2
if there's a fuse there's probably a wire...somewhere.
On Kubota's the wire is under the fender by the tail lights and comes on with the key so the light needs a switch.
   / need help wiring aux lights #3
There is a power and ground wire wired in already. Look at right rear corner just below the tool box shelf, there are 2 wires with round "bullet" style plug connectors for rear work lights. Wire is hot, no switch, so you need to add a switch with the lights.
great thank you
i have them wired and have plowed a couple times, works great thanks for the help.
just a el cheapo from tsc but it gets the job doneimage.jpgimage.jpg.. not sure if this will work i am trying to do this from my iphone and im having trouble.
   / need help wiring aux lights #9
Looking good. Thanks for pictures. You just used some heat shrink butt connectors?
there were already butt connectors there so i greased then used them.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
Cat TH407C Telehandler (A53472)
Cat TH407C...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
