Need Help...tc29 stuck in gear.
   / Need Help...tc29 stuck in gear. #11
You transmission shifter forks have slipped out of alignment with the shifter thus locking it in gear. I am not familiar with your tractor but in general you need to remove the gear shift and get access to the shifter forks and realign everything back to neutral. I have an older tractor which occasionally suffers this situation and now I can fix it in about 10 minutes. Just don't go forcing anything or you will break it big time. It should not be a hard job
Dave M7040
   / Need Help...tc29 stuck in gear. #12
It is hard to tell from the pics on the N/H site but there are usually detent balls and springs that hold the trans in gear. If the detent ball gets wore it can get stuck and wont let it come out of gear.The parts diagram shows them but I am not familiar with your tractor so I can not tell you how to access them. On my 1900 there are bolts on the top trans cover that hold the detents.
Bill
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
Bobcat T590 (A53317)
iDrive TDS-2010H...
