Need help sizing a rotary cutter
/ Need help sizing a rotary cutter
4' cutters seem to always go for more than 5' cutters. Just not as many of them around, and not as popular. Same with 6' cutters. But 5' ers are plentiful about everywhere.
I have seen quite a few 4/5 for sale most have been brand new top dollar a few rusty beat old ones for cheep but not any great deals. Not too many 6 out there.
/ Need help sizing a rotary cutter #22
$900 is a great price, I haven't even seen a decent 4 for that!
That's why I have a 5 footer rather than the 6 footer I was looking for. I knew that routine mowing would be with my 6+ft flail so I wasn't that concerned about number of acres per hour mowed etc. And as it turns out, in thick brush it is sometime better to have a slightly undersized bush hog just to concentrate power and increase maneuverability. All things being equal I'd have gone for a six footer but the price on the barely used BB600 was just too good to turn down.
/ Need help sizing a rotary cutter #23
$900 is a really good price for a BB600X. I paid $3500 for my BB720X. Size wise, I do like that the cutter is as wide as my wheels for my ability to quickly clear spaces. I'm running my tractor at 2000 rpm in the following video the only time I bog down is when I'm mowing dirt, rocks, and large windfalls.
/ Need help sizing a rotary cutter #24
No doubt the BB720 is the preferred and standard bush hog size for a 40+hp CUT.
The way I use my BB600 however is mostly in backing into thick brush. I cannot walk the area before cutting as it is thick brambles and briar and so I couldn't be sure about absence of obstacles anyway. I call my technique reconnaissance by mowing. I simply make what looks like the start of a Y turn, back into the brush about 8-10 feet then pull out, move 5 feet along and then back in again.
As I don't drive forward with the brush mower often the narrow width doesn't bother me.
That video is great! It sounds like a vacuum while in high speed!
/ Need help sizing a rotary cutter #27
I vote for the 6'. My TC40DA is HST with 33hp PTO and it handles my 6' Bush Hog OK. I mow at 3 mph, any faster and I can't walk the next day. :) In tall grass it will bog down occasionally but I just slow down and let it catch up. Even my Boomer 8N with 40hp PTO gets bogged down occasionally with it. Just more time on the tractor enjoying my music.
The TC40DA has an FEL, the Boomer does not. The Boomer 8N was light in the front end so the mower would push it around some. So far I have added 200# of tractor weights on the front of the Boomer 8N. I have to buy a bracket to add another 300# of weights on the front.
I don't think I will need weight out front, the tractor is about 6500 lbs, my finish mower is about 600 (I know it doesn't hang as far back) and I can't even tell it's back there. I usually drop the bucket off the loader so I can get closer to the fence and it's never felt light up front. Last year I borrowed a 25hp (engine) new holland and put my 6' mower on it and that tractor could really tell it was back there! I didn't lift the mower more than a few inches if at all and needed 4x4 to steer! That tractor was tougher than I would have guest, it ran that mower well everywhere but the tall thick grass.
/ Need help sizing a rotary cutter #29
I can't drive fast enough to make my 5' one make the tractor work. I regret not getting a 6'. I also have a braber/agriease chinesium model with a 40hp gear box and it runs cool and there's nothing scary in the oil when I change it. It's no heavy duty beast but its snapped a few shear pins on dirt and has a proper round stump jumper. Its eaten 2" brush and "finish" mows my neighbors trails when I sharpen the blades. Of the light duty ones I looked at, it was the heaviest built and had the best paint, and had decent welds. If you are mostly just mowing fields and trails like me, I don't think there's any need to spend $2k on it.
/ Need help sizing a rotary cutter #30
6ft is fine for a finish mower, it could probably handle 7 if you wanted, but no need. 6 would be fine for a brushog, but 7 would be really pushing it there. You don't want to go narrower than the rear width of the tires. I have 5ft brushog on my CK35 (600# homemade deal, used for $200), and no issues with power. 6ft would be pushing it, but if I got a RFM I'd go 6ft. The rule is 5 PTO HP for every 1ft of mower width, by that you're good at 6ft for both a RC and RFM. One of these days I want to dig data on recommended HP for a bunch of mowers and crunch numbers on whether that is actually a workable rule, but that's for when I have more time. For now, I just run with it.
/ Need help sizing a rotary cutter #31
You change the oil in your mower gearbox??
/ Need help sizing a rotary cutter #32
I have a BB60X I think it's called, a 5' woods brush hog for my ck30hst and it doesn't stutter.. I cut 22 rabbit shooting lanes in a 3/4 mile long thick CRP field right after deer season ended super bowl Sunday morning and it didn't miss a beat.
/ Need help sizing a rotary cutter #33
My older model DK 35 has the same basic engine as your CK 35. (I have 34 HP, 28.3 PTO HP).
I run a standard duty 6' brush mower, handles a 7' rear finish mower no problem, and a 6' tiller.
Now that's a good day hunting! I didn't see one rabbit last season while out grouce hunting. I have been busy the past few weeks but I still need to call around on some of the lighter cutters. Also does anyone know why my Gmail account recently decided that all the emails from tractorbynet.com belong in the spam folder?
/ Need help sizing a rotary cutter #35
I think you can. I don't, but I do check it every once in a while, and top off if needed. Maybe I should change it now and then. This year's project will be getting the blades off to be sharpened. I don't know the last time those things were off, but it's been a while.
/ Need help sizing a rotary cutter #37
I just top mine off too. Changing oil is for engines and precision pumps that suffer from particulate matter in the oil. I've always thought you could keep a mower gearbox happy with any oily substance from fine oil all the way to bacon grease if necessary. I keep mine topped off with 90w but I cannot imagine actually changing it.
/ Need help sizing a rotary cutter #38
I tend to go with implements the same width as the stock loader bucket. Lack of power is never an issue and I know the implement can follow wherever the the bucket goes.
/ Need help sizing a rotary cutter #39
I think you all have me convinced to go with a 6', thanks for all the advice.
Good. You can always cut 5' with a 6' cutter (or slow down or both). No way in heck to cut 6' with a 5' cutter.
My 6' weighs around 1000 lbs and I wish it was a 7'.
Based on what you're cuttin, what don't u like abt the finish mower?
I would go 6'.
Here is my 8' on 45pto hp. Cutter spec sheet calls for 50pto hp but it does just fine.
http://www.tractorbynet.com/forums/attachments/341915-landpride-8-rotary-cutter-review.html
The mower itself has been great, and it's fine for the pastures. I have 50 acres of woods full of stumps and rocks I don't take the finish mower out there, I borrow an old bushhog to cut the trails but I hate borrowing something and hitting stumps or breaking it. Also the wood lot and the pastures are 10 mile apart so that bushhog never makes it to the pastures (I can usually only get it for a day at a time) alot of the edges need reclaiming from the forest. If I had the funds I would keep the finish mower and get a bushhog but that's not an option right now.
