Need Help Replacing Work Light Bulb
/ Need Help Replacing Work Light Bulb #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
I need your help! I have a magnetic 12volt worklight I purchased at TSC. A few months after I bought it, it stopped working. I took it apart, and I found that the filament in the bulb was broken. Now I can't get the bulb out to find a replacement. I tried and tried, but it would not budge. I was wondering if anyone on here knows a way to get it out? I would really hate to toss the whole $20+ light just because the bulb is broken.
Of course, attached are some pics:
Thank for any advice you can provide.
/ Need Help Replacing Work Light Bulb #3
Looks like an H3 bulb, the lead comes with the bulb. I dont see hows it mounted but seems like the most logical. Google H3 bulb and you should get a lot of hits.
/ Need Help Replacing Work Light Bulb #4
If you follow the link provided by ThomasH read the reviews. There 4 I think, 2 good, and 2 negative. Both of the negative reviews address bulb life, which was apparently very short.
/ Need Help Replacing Work Light Bulb #5
looks like a headlight bulb. The metal base plate is part of the bulb. The new bulb should have a lead too.
/ Need Help Replacing Work Light Bulb #7
G'day as said it is a H3 globe and it comes with the pigtail on it you will have to pop the rubber grommet out of the base of the light and you should see a blade type connector.
Jon
/ Need Help Replacing Work Light Bulb #8
I'm with banjodunn, pull out that little rubber grommet and follow the wire to it's connection point. The glass bulb doesn't come out of it's mount - it's all one piece. Those bulbs blow easily mostly from vibration - especially when they get hot. Good luck....
/ Need Help Replacing Work Light Bulb #9
The bulb runs about $5 to $7 and should plug in somewhere on the other side of the gromet. And the life life can very do to vibration . Some times Wal-mart is closer to $5 , get two then you will have an extra bulb, for next time ...
Thanks everyone for the help!
I was looking at the problem all wrong by trying to take out just the bulb and not the whole unit. I found the connector, and the rest was easy. I will look for the replacement bulbs later this week.
Thanks again.
/ Need Help Replacing Work Light Bulb #11
WOO HOO. Don't you just love it when a plan comes together?!? :drink:
/ Need Help Replacing Work Light Bulb #12
G'day I forgot to say that this is a halogen globe and because of this do not touch the globe with your fingers as the oil from your fingers will cause hot spots on the glass causing it to crack and blow the globe.
If you do happen to touch the globe then wipe it with some methylated spirits or some other alcohol based cleaner, I usually hold the globe with a tissue while I am fitting it to the holder.
Jon
Yup. :)
Jon
Will do! :thumbsup:
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2003 Keystone Cougar Camper (A66285)
2003 Keystone...
