Need Help Please !!!! MF 50? industrial
   / Need Help Please !!!! MF 50? industrial #1
Terry T
Niagara Falls, Canada
Ford 8N & Massey Ferguson Industrial
I have no clue about this tractor only that it followed me home last week. You know the deal that is too good to be true. Anyways my problem is "what is it?" and what is the fluid that it used for the "shuttle shift?" I was told reg. trans fluid? and for the perkins 4 cylinder engine, what filters or service info is out their? Thanks for your time and help.
Terry T (Niagara Falls, Canada)
   / Need Help Please !!!! MF 50? industrial #2
I looked at tractordata.com but they don't have much info listed about industrial tractors. They have the models listed just no info. I'm sure Farmwithjunk will probably be able to help you out on this one. Look for any tags with serial / model #s.
Serial plate says 9A 97639 but no one has that number listed? The cab is a after market i found out , MF didnt make cabs then? Im starting to think I made a mistake in letting this tractor follow me home. My wife keeps saying " stop bringing home all the strays". Thanks for your help.
Thanks so much, i so want to start working on this tractor butfirst things first. Owners manual, so many filters so little time. Then what type of fluid does a shuttle shifter take, leaked most of it out and hard to stear as well. Big and ugly but with a little love, and some paint it will be as pretty as my 8N. Thanks again for your help, i check this site 2-3 times a day waiting for some one to help me.
Terry T
(Niagara Falls Canada)
   / Need Help Please !!!! MF 50? industrial #6
Trans and Diff Extreme pressure Transmission oil Conforming to Massey
Ferguson Spec # M-1129 Filters Napa or Massey dealer can match up
   / Need Help Please !!!! MF 50? industrial #7
I have a 30E A little smaller machine . Industrial TLB shuttle shift .
The transmission takes MF Permatran III. There are any number of cross over oils. Just read the can and look for Permatran III. It is not straight hydraulic oil. My machine takes almost 15 gal between transmission and rear end. This spring I will do the 1000 hr change for the first time and I never expect to do it again. I know a fair amount about the machine , yours is older I think but maybe I can help. MF ag is now owned by Agro. MF industrial is owned by Terex. The local MF ag dealer here told me he can get me any parts I need.
   / Need Help Please !!!! MF 50? industrial #8
picture of mine
   / Need Help Please !!!! MF 50? industrial #9
The transmission takes regular red automatic transmission fluid.
If the steering is stiff look on the right hand side of the engine at the front and see if there is a small pump driven by the fan belt, this will be the power steering pump if it has one fitted. Turn the steering wheel one complete revolution to the left, remove the filler cap and check the fluid level in the steering pump reservoir, it should be filled to the bottom of the neck with the same red transmission oil.
It is a long time since I worked on a MF50 so I can't remember the filter numbers but you should be able to take them out and have them matched up at a filter suppliers.
   / Need Help Please !!!! MF 50? industrial #10
Good call, Paul. That usually cures heavy steering in our MF50 Industrial.
It's been a good starter, after some kids left the tank cover open and we got a dose of water through it and that upset the pump.
Also, I'm about to fit a front end loader to ours. It's from a Ford 5000 industrial and on the Ford, the main pump was driven from a tlke off in the bellhousing and a driveshaft ran along to the pump behind and to the left of the driver's seat. I suspect the MF 50s used a front mounted pump, probably driven through the hole in the front axle pivot.
Can anyone confirm that, please? Also. where was the hydraulic tank located?
   / Need Help Please !!!! MF 50? industrial #11
G'day just done an engine rebuild on a 50H and it's hyd res is in the l/h loader frame upright and the pump is driven through the hole in the axle pivot also the shuttle shift takes dexron 111 or equiv as prev stated
Jon
   / Need Help Please !!!! MF 50? industrial #12
I am with u I have one for a year kind of lost. And have a oil leek out of trans at a cotter key
   / Need Help Please !!!! MF 50? industrial #13
Probably a bad seal inside or a blocked filter screen.
Not sure about the MF 50,
But my MF60 Industrial takes MF Permatran III or equivalent, not the red trans oil.
   / Need Help Please !!!! MF 50? industrial #14
What color is the oil you are leaking? If it's red, the front seal is out of your transmission (the above posts say that the MF50 uses DexronIII for hydraulic oil) that's transmission fluid for cars., if it's not red, then it's more than likely the rear seal on the engine and engine oil is coming out where the cotter pin is.
   / Need Help Please !!!! MF 50? industrial #15
rear hydralic lift will not raise the gannon. i have rebuilt top cover cylinder and piston
   / Need Help Please !!!! MF 50? industrial #17
MF is owned by AGCO not Agro.
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2021 JOHN DEERE 50G EXCAVATOR (A60429)
2021 JOHN DEERE...
2022 TAKEUCHI TL8R2 SKID STEER (A60429)
2022 TAKEUCHI...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
