Need help on estimating shop lighting requirements
   / Need help on estimating shop lighting requirements #21
This is a simple to use and awesome resource for lighting. You need to create an account but it is free, and they don't spam you:
LightCalc Login
   / Need help on estimating shop lighting requirements #22
I've used them on commercial jobs. They are efficient, very good lighting, but the down side is you really need a lot of ceiling height to get even light distribution, I haven't seen long ballast life, and they are staggeringly expensive.
I did some research on these lights before deciding on them. I did read about the ceiling height issue but was more interested in getting lumen output close to what I had. T5 came close. I installed it centered in shop parallel to long wall. Brightness is good and I don't see a problem with ceiling height. The fixture does not have a reflector so I am going to add one and see how that does. I am satisfied. Cold starts are not a problem but it was a problem with my old fixture. My old fixture, about 30 years, is industrial so the height requirement may have applied too.
   / Need help on estimating shop lighting requirements #23
The most cost effective way to wire is EMT use 10' lengths to separate lampholders, use 165 Raco or equivalent. Arlington 800 and 370. Get ground screws. place the boxes in an E pattern, I would run down the front wall above the door where doors won't hit it and lights won't burn the ceiling. I'm guessing a two bay, 3 boxes each side of overhead doors. Bend Emt to fit to ceiling, run with 10' or shorten to gain one more light in each bay, With 9 or 12 boxes. Use Leviton 29816 C2 porcelain sockets with pull chains. #14 solid THHN three conductors (black white green). Ideal 341 wire nut, use a solid tail #14 12" long to connect each color together Use ground screws (special for the purpose) to ground each green to the box. Strip 5/8" on each, don't be lazy, twist until you see two full spirals of each conductor outside the wire nut. After mounting fixtures on boxes, staple one end of a 8" piece of light chain to the ceiling about 14" away from box. Run pull string through other end before connecting to fixture. Home Depot sells a (compact fluorescent) 68 watts (replacement for 300 watt incandescent)
Power all of this through a switch on the wall. Use the pull strings to turn off unneeded bulbs.
Happen to have any pics of this type install? I too am getting ready to start a garage project and am estimating electrical cost this weekend - I like this approach
   / Need help on estimating shop lighting requirements #24
Whats the best way to estimate shop light requirements? A few years ago I built a 24 x 26 garage with a 10' ceiling. The interior walls and the ceiling are finished with standard unpainted OSB and the concrete floor is painted white (you would be amazed how much that helps lighten up the inside of the building). I finally got around to running 100 amp service to the building and I will be using conduit and boxes to run all the wiring. I am tryng to determine what type of light fixtures would work best in this appliation and how many fixtures I will need. I prefer a brightly lit building interior over a dimly lit building interior. Would appreciate some opinions. Thanks.
Good Mornin jeepcj7,
Back in 2010 I built a 28 by 44 barn, partitioned so that my shop section is about 19 by 27 inside dimension. I also have 10 ft ceilings and the floor also concrete, I have not painted my floor. Ceiling and walls are sheetrock in that section of the barn and painted off white. I use 4 T-8 fixtures, four bulbs each fixture, and they really light that shop up ! Like you stated the white makes a big difference. I would think that the only additional light you might need would be a bench light for some very intricate work JMO .....
   / Need help on estimating shop lighting requirements #25
Not sure if you're still looking for input or not but I have a very similar garage, 24 x 24, plywood walls painted a sort of light beige/army green and bare concrete floor which is the typical light gray. There's no ceiling so I just hung four 8-foot, 4-tube T8 fixtures off the horizontal lumber 11 feet from the floor, in the center of the space from side to side and evenly spaced front to back. The 16 tubes are 32 watts each so that's 512 watts for 576 square feet.
It's not lit up like a body shop but I've found the electronic ballasts to be very quiet, quick starting in the extreme cold (single digits and lower lately), and plenty bright once they've had a chance to warm up for a few minutes in these temperatures. I also have a separate four footer over my workbench in the corner but other than that I've found that the arrangement provides adequate light for the work I do. If you're a lot more picky about dark areas and ensuring every corner is bright I would go with the industry's formulas instead of going on experience like I did. I used to work for an electrician and I bought and installed everything based on the jobs we did over the years.
It sounds like you're doing it right with the big service and the conduit. Post some pictures when you're done if possible. Everybody likes to see the final product. Good luck.
   / Need help on estimating shop lighting requirements #26
I installed and repaired all of the 8' double tube units in a friends upholstery shop, they worked great.. but.... when we went to Home Depot to get a couple of ballasts, the display had some lights that used a small diameter tube and they were over twice as bright.. newer technology.. I reommend checking them out, can't remember which units, but when you look at the display, you'll find them easily, they are so bright you won't stare at them and they outshine the others by a mile..
   / Need help on estimating shop lighting requirements #27
My original garage I built is similar to yours. It's 24 x24 with 14' ceiling. Built it high because I have a two post car lift. For lighting I originally used 4' 2 tube T12 fixtures but after many years and T12 tubes not being made anymore I replaced them with 4' 2 tube T8 fixtures. I have 8 total. 6 are suspended down 4' on chains and 2 are mounted to a side wall. Then I added an 18 x 32 addition on the back of the garage. In there I used 2 rows of 4' T8 fixtures also hanging on chains (8 total) and one more over a work bench. All the T8 fixtures I used say for cold start use. The main garage is not heated unless I need to work in there. Then I use a kerosene salamander for heat. The back addition has a mobile home oil furnace for heat. I have that set for 45 degrees and bump it up to 60 if I need to work out there.
   / Need help on estimating shop lighting requirements #28
LightCalc Login
Yup, but I'm usually right. I was told this was a Ben Franklyn quote, but I can't find it. Until now I claimed it as my own,and got away with it.
   / Need help on estimating shop lighting requirements #29
the small diameter tubes are the t5's.
the best t5 are the 54 watt variety. but the problem is if you have a 6 lamp t5 your looking at 300 watts power use. so you dont want to go crazy with them. They also work best when there set above 15'.
   / Need help on estimating shop lighting requirements #30
Be careful, there are some 27 watt T5 fixtures at Home Depot, They don't throw a lot of light, don't light well in cold, bulb and ballast life are short, I can't find replacement ballasts from usual sources.
Although HO 54 Watt T5,(5/8") are the future of fluorescent, they will soon be eclipsed by LEDs consuming less than half the power. Even very high quality HO T5 fixtures seem to have short ballast life.
For a small fraction of the cost you can have Leviton 29816-C2 porcelain sockets with CFL 68 watt (300 watt equivalent) from Home Depot. These will give better light distribution, energy efficiency, (a light not needed need not be on)
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
RoGator RG1100C (A51039)
RoGator RG1100C...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
