Need help installing work lights
/ Need help installing work lights #1
glagen
Hopedale, MA
JD 4310 & X595
I bought Auxiliary Forward Light Kit #LVB25023 and Rear Lights #TY16053. The front kit comes with instructions and the lights mount appropriately on the Brush Guards JD sells. The rear lights don't come with instructions and probably fit a multitude of applications. The wire pig tails are very short and the lights don't appear to fit anywhere on the ROPS. Has anyone mounted both sets on a 4310 or similar model that can offer advice on correct mounting? Thanks.
Steve Z
/ Need help installing work lights #2
Mine mounted in a square hole (for the carriage bolt) in the fender. You can mount one on each side if you like. The electrical plug should be long enough to reach the extra plug that is down next to the fender.
/ Need help installing work lights #3
The rear work lights mount on the inside of the rops and below the level of your tail lights.
/ Need help installing work lights #4
glagen:
This $.02 may strike you as a Ph.D. in duh, but there are holes in your ROPS for mounting worklights, etc. These may be shared with the existing directional/hazard light mountings. Don't drill the ROPS with even the tiniest hole; doing so is super dangerous due to the weakened structural integrity and will also void warranty, etc.
JDLou
BODY LOAD TANK (A67714)
BODY LOAD TANK...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
55 GALLON BARREL TOTE/ OVERHEAD CREEPER (A67714)
55 GALLON BARREL...
KOMATSU WA-250 GP Bucket (A68134)
KOMATSU WA-250 GP...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
