Need help finding nut
/ Need help finding nut #1
ernemats
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Does anyone have any information on where I might find a nut off 422 wheel motor other than power trac? It is a 3/4 castle nut 28 thread per inch. I have tried NAPA , hydraulic repair shops, fastenal, surplus center without any luck. Can get it from power trac but $50. minimum order. Thanks for any help.
/ Need help finding nut #3
The last time that this came up, I poked around the internet and found a couple of sources. Try searching on the thread size plus castle nut, but you might want to double check the size; Scotchers had it measured by someone else at 1"x20. (The way the TBN thread was left it was unclear what the correct size is.) You might want to PM Scotchers to see what he did.
MR posted a link to a local store that had run down nuts for him;
http://www.midstatesbolt.com/
Rethreading a shaft subject to large forces is not something that I would take lightly. By rethreading, you can, and usually do, lose significant thread strength.
The topic is rife with potential puns...
All the best,
Peter
Just throwing this out...Have you thought about re-threading the bolt for a new castle nut you could buy at a hardware store or HD ? Just a thought.
I checked with Keith at power trac and he confirmed it is 3/4 castle nut , 28 thread per inch. I have called at least 50 different places and no luck. I guess I will order it from power trac. Thanks for input.
/ Need help finding nut #5
Just a question, but what happened to the original nut?
/ Need help finding nut #6
Scag mower uses a 3/4-28 castle nut on their mower. You might have a dealer in your area. If not try Mowpart.com or other online sources. Mowparts price is $9.42. Scag part # is 48679. Hope this helps.
The original nut came off while I was plowing snow. I found the nut about 100 yards from where the wheel fell off, the threads were ground down on the nut but are ok on the shaft it seems. I knew the key way on the hub was getting worn and I had ordered a new hub when I had my tram pump rebuilt by power trac back in the middle of November, but I just never got around to replacing it. Luckily the wheel fell of right in front of my garage and I just raised the front of the power off the ground with the snow blade and put it in the garage for repairs.Attached picture of nut not real clear.
Tried scag dealers none stock it. Called mowparts and they do not stock it or list it they said.
/ Need help finding nut #10
It is Mowpart.com, not mowparts. You can go there and type in 04027-02 or call 972-635.7225. Maybe this will get it.
Thanks Winston . I found a place in Michigan that stocked the scag part # and it is on its way. No minimum order but shipping was as much as the part.
/ Need help finding nut #14
Yeah!!!
Streamers and cheering!!!
Nothing like the thrill of the successful hunt...except perhaps the feelign that comes with finally reassembling whatever needed the obscure part in the first place.
Congratulations.
All the best,
Peter
/ Need help finding nut #15
If you aren't in a hurry, I can pick one up next time I drive through Tazewell - probably sometime next week. It shouldn't cost much to mail it.
Thanks for the offer but I received the nut by fed ex today . Put it on and plowed my driveway and spread some anti skid on the ice with the seeder. I did like Terry said I put it on with the impact wrench.
Caterpillar E120B Excavator Service and Parts Manuals (A63117)
Caterpillar E120B...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Wacker Neuson...
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
UNUSED WOLVERINE QUICK COUPLER 4 (A64281)
UNUSED WOLVERINE...
