Need Help - F24 Overheating
/ Need Help - F24 Overheating #1
adt2
Magnolia, TX
Yanmar FX24
Some of you may have some of the backstory to this problem from my "Where are these fluids coming from?" thread. To recap: My F24 starts and runs fine (and, as of a few days ago, has no more oil leaking out the oil pressure sending switch). However, after less than 10 minutes at normal operating speed, the temperature gauge on the dash is redlined. No smoke from anywhere. The radiator is not spewing water into the overflow tank, but there do seem to be bubbles in the tank (air coming from the clear hose attached just below the radiator cap).
I mistakenly removed the temperature sensor and boiled it, thinking it was the thermostat and I was checking it for proper operation. (Sheepish grin.) It's been reinstalled now. I've removed the two-bolt flange that the top radiator hose is clamped to, but I didn't know what I was looking for (or looking at) and frankly I can't remember seeing a thermostat down in there (on the engine side; I didn't think to look up into the radiator side and see if it was up there).
I am *not* an engine guy, but I can follow directions and am not afraid to get my hands dirty. So far, all I've done is check the fluid in the radiator, and the steps listed above. Short of any advice to the contrary, my next step will likely be to flush the cooling system and then re-check things.
/ Need Help - F24 Overheating #2
Didn't see it until after I logged in!! Look at the last reply Where fluids are coming from. Rent a gauge it will have or even may have Instuctions for you also. Read Radiator Pressure test you can actually make one.
My Internet is mess up bad here's a web site.
How to Perform a Radiator Test - Autos.com
/ Need Help - F24 Overheating #3
Check the thermostat. It must be removed to flush anyway.
/ Need Help - F24 Overheating #4
Were is the Thermostat on the F24 just to clarify were it's located? Apparently not under the Flangy thingy do hicky.
/ Need Help - F24 Overheating #5
Unless missing, it should be where the upper hose attaches to the engine, either inside or under a housing. Have never seen a F 24, but that's where all tstats are located.
/ Need Help - F24 Overheating #6
Flush Away!!
/ Need Help - F24 Overheating #7
/ Need Help - F24 Overheating #9
Yup! The Master of the Manuals. Getting a little slow finding this one though.
Bad news: my tractor is missing part numbers 2, 3, & 4 shown in the exploded view above. Other (bad?) news: the radiator cap holds pressure indefinitely, but the radiator itself holds no pressure at all. It leaks air as fast as I can pump it.
Leaving the gauge on the radiator and starting it cold, the pressure slowly climbs to a max of about 12 psi. At redline on the temp gauge, psi was about 7 or 8. It climbed to 12 psi when I backed off the idle speed to let her cool down.
Is there a question here?
This whole thread is an ongoing question, but if you need something more specific, I suppose "Is ordering and installing the missing thermostat parts from Hoye the logical next step, or is there something amiss with the radiator pressure that needs to be addressed first?" would be where I'm at this morning.
/ Need Help - F24 Overheating #13
A tstat is totally unnecessary. Fill the radiator with water, pressurize and see where the water is going. Back-flush the system.
Do you mean by running the engine? That's the only time it has any pressure. Or will filling it up allow me to pressurize it with the test kit?
Okay, I'll head back over there tomorrow and put the gauge on it again, see what I can suss out.
In the meantime, I'm a little fuzzy on the whole "a tstat is unnecessary" comment. Doesn't the thermostat serve some kind of purpose? Or rather, what purpose, exactly, does the thermostat serve? What am I missing (damaging / destroying / neglecting / etc.) by not having one installed as shown in the drawing?
/ Need Help - F24 Overheating #17
Thermostats control engine temperature. They open at a certain setting allowing coolant to circulate. (160F on these Yanmars) They open only enough to maintain that setting. If one is not installed your engine could run a little to cool in cold weather but hot weather no problem. Personally if the model came with one I would want one installed but I'm sure many run without them.
/ Need Help - F24 Overheating #18
Get the missing parts and the overheating should be fixed... I raced round track cars for years... Yes..Thermostats control engine temperature. But it also controls the speed that the water travels through the engine... If it goes through the engine to fast it can’t pick up the heat as well... If it does not stay in the radiator long enough it can't get the heat out of the water... Back in the racing days anyone running a car without a thermostat over heated... We would put in a restrictor about a 1 inch hole in place of a thermostat...It was a big washer a flat thin piece of sheet metal with a 1 inch hole in it or we would take out the center of the thermostat… This was used to slow the water speed down to give the radiator time to cool the water and give the water in the block and heads time to absorb the heat into the water... Think about it if a tractor would run at the right temperature without the thermostat and gasket or o-ring… Don’t you think the tractor manufactures would just leave them out and save millions of dollars in parts they have to install…
I ordered the parts yesterday or the day before. Whether they're necessary or not, something in my nature rebels against obviously missing pieces.
/ Need Help - F24 Overheating #20
The thing should not redline that fast even if it had no cap on it i dont think! something is a miss here. We need to confirm that sensor and gauge are reading the correct temp. And that the radiator is not clogged up next. and any water passages in the head/block (pain in the but)
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
2007 Flatbed Dump (A62613)
2007 Flatbed Dump...
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
2025 44in Hydraulic Grapple Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
