Need Help - F24 Overheating
/ Need Help - F24 Overheating #81
Not sure how your fan is but you can leave the fan off for just leak checking now if its built onto a likely out something that won't work.
I can't remember how the 2000 is let alone your tractor I have never seen.
/ Need Help - F24 Overheating #82
Okay, good news and bad news, I think. I got everything put back together a few days ago. Filled the system with clean water and then went home for the day. When I got back the next morning, there was some water on the concrete under the tractor, but I think it might've been from a little overzealous radiator filling on my part. I dried it up and went back home.
It was a couple of days before I got back out there, but there didn't seem to be any new moisture on the concrete. Good sign, I guess. Anyhow, I put the radiator tester thing on and pumped it up to about 15 psi. The system mostly held the pressure, but after a few minutes, there was a steady drip. It looks like it was coming from a little hole on the front right side of the water pump (see photo; the little hole in question is directly above the bolt head on the hose clamp smack in the middle of the image).
I crammed a rag down in there to catch that drip, dried the concrete, and waited. A little while later (maybe 20 minutes? lost track of time working on the boat) there was a whole new drip. I cannot see where it's coming from, but it appears to be the underside of the water pump (see photo; this is not a very useful image, but I can't get a shot of where the water is coming from. It appears to be coming from back up under where the hose is attached, somewhere on the body of the pump).
I'm hoping these leaks are indications of a bad gasket or something similar. My birthday is next week; karma could give me a nice present by making this a quick, cheap fix.
/ Need Help - F24 Overheating #84
Looks like the water pump weep hole. A new water pump is in order.
Okay, I can get that from Hoye no problem. Just out of curiosity - what does water coming out of the weep hole indicate? (Other than "you need a new water pump.")
/ Need Help - F24 Overheating #88
Yep bad seal...from worn seal or sloppy bearings that allowed the seal to go out. Replace water pump. Also dont leave straight water too long as you rust your block after a short time. Fine for testing but need to drain it or put a small amount of antifreeze in it.
Well, the comedy of errors continues...
Got the new water pump assembly in the mail yesterday and went over there today to install it. Managed to damage the threads on one of the mounting bolts, so I had to stop in the middle and run to town to get new bolts. When I got to the hardware store, it became apparent that I had inadvertently grabbed the bolt with the damaged threads as my example, and I was unable to thread a nut onto it to determine what size it was. I ended up buying four each of several sizes and headed back.
Got it bolted on (ended up being 8mm bolts) and realized I'd left the fan belt off. Took it back off, put the belt on, and bolted it on again. Installed the thermostat, and then realized the new gasket Hoye sent was in three separate pieces. No idea if it was damaged in shipping or during packaging or what, but it was worthless. So I re-used the gasket that was on there before, and put everything back together.
Filled the system with water and put the radiator pressure tester thing on it. First pump, water shoots out of the thermostat gasket like I was holding my thumb over the end of the water hose. Argh. I really couldn't even tell if water was coming out anywhere else because so much was coming out the gasket area. So I called Hoye and they're sending me a replacement gasket.
I'll update next week with whatever my next disaster is.
/ Need Help - F24 Overheating #91
You could assemble with silicon? You have to take the water pump off to put the belt on??? I think you needs to find what adjusts and loosen that...usually the alternator.
Think about it you should not have to remove the water pump to replace a belt!
I hope this fixes your problems!!!
No, not the pump - the radiator fan mount
Sorry for the confusion.
/ Need Help - F24 Overheating #93
ok got ya.
still thought you should be able to slip it by...i guess not?
No, I was trying not to loosen or remove anything that didn't absolutely have to come off, because I wasn't sure how much of a hassle it was going to be to retension the belt correctly. It wasn't a big deal - took about five minute to pull the fan mounting hub thing off, slip the belt onto it, and then lever it back onto the hub.
/ Need Help - F24 Overheating #95
well the anticipation is killing me!!!! HAVE you run it yet? inquiring minds want to know!!!
I can't run it until I get the replacement gasket. Probably going to be the middle of next week. Believe me, I am as anxious as you are to get this thing running and get it out of my barn.
/ Need Help - F24 Overheating #97
If you are pumping to 15 psi you are causing your own leaks. An intact used tstst gasket should not leak.
I never got close to 15 psi after installing the new pump. It leaked after one pump of the handle.
/ Need Help - F24 Overheating #99
Something wrong there other than the gasket. A used, intact gasket should not squirt under moderate pressure, mild seepage at worst.
Make sure the bolt holes are not filled with debris, causing the bolts to bottom out before seating the housing. Happened to me once on an old car.
Also, some waterpump bolts go through to the water jacket and will leak if you do not use pipe thread sealant.
Something wrong there other than the gasket....
Would not surprise me in the least, considering the way the rest of this project has gone. As near as I could tell, the water was ONLY coming out where the radiator hose connects to the top of the water pump (thermostat area), but frankly there was so much water that I really couldn't tell if it was coming out in other places, too. I should have the new gasket in a day or two, and it won't take long to install and test again.
While we're on the subject - what's the proper psi to pump the test kit up to?
213091 (A64276)
213091 (A64276)
Deere 670G (A64126)
Deere 670G (A64126)
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
8' X 16' FARM WAGON (A64276)
8' X 16' FARM...
