need help designing a homemade loader
/ need help designing a homemade loader
Have you looked through the sites found on Google images to see how they mounted their loaders?
Bruce
What did you type in?? Can't zoom
farm king 990 loader
This is a different tractor. It's a homelite Jacobson. But thanks it's still a help. I couldn't find anything but i was searching homemade loader
Well i know allot of you advice upgrade the front end. But to me and my father (doing all the welding with 40+ years of tractor experience) we are not going to upgrade the front end. We ain't going to make this a huge loader. We know we will be lucky if it will not be able to handle thousands of pounds. Our Max lifting will be less then #500. We are going too use one of our old high jackers as the uprights for mounting the loader and the forks for loader forks
/ need help designing a homemade loader #25
No Johnny loader will ever be bought around here.. JUNK JUNK .....I would image it would have a Stronger frame and axle then a lowes tractor
I said "look at" for ideas , not "buy" ..... your front axle may be HD but the wheel spindles won't take 500 lbs .....
you asked for suggestions , you got 'em from several members that have or built their own ...
it is advice , you are welcome to use it or not , your decision ....with no pressure from any member
it is your tractor , project and your $$$$$ :)
/ need help designing a homemade loader #26
I'm sorry that i might have seemed rashed or anything about this. I didn't mean to but that's usually how my text sounds like.
I do appreciate your suggestion but the Johnny loader is a no for here on our farm. We don't really like those style
/ need help designing a homemade loader #29
How much is a used 20hp Chinese tractor with a loader?
$5,000+
Can find old kabota tractors for about $3500-$4500 but that is a half worn out with no loader
This tractor was $250with a rusted out deck and a push mower. I have priced everything for a loader for $500-600
/ need help designing a homemade loader #31
What kind of hyd cyls are you looking at?
for this I'm looking at lifting with 1
2-1"×36" or 48"
Then the tilt. There is a 2"×24" cylinder with the unit i want
/ need help designing a homemade loader #34
You better grab that deal. The cyls would be real close to that price. That stone pump is a good one. I used them on my pontoon trailers when I was in Rockton, Ill.
/ need help designing a homemade loader #35
I see you posted on another thread wanting some more pictures,
but one thing that can save one a lot of problems is to make a mock up of one side of the loader using the real cylinders, laying out on it side using either wood or cardboard to represent the loader frame and the loader arms, to see if the geometry of the swing is correct, IF you use actual size pieces, one will be able to see if things are going to clear and not pinch, Fittings clear, (we had one old commercial loader, when raised nearly all the way up, the fitting would hit the frame , snap it off and dump the oil and drop the load), some times the clearance on a mounting ear will need some more clearance, etc.
and to see if the lift and arc is what you want, moving a mount a few 1/8's of an can make a lot of difference some times.
one thing I thought was innovative was on the cad loader, https://www.cadplans.com/cadloaders/cadloaderlt-model-507.html the 507 model with single arm, for a law type tractor, (first the garden tractor is so small a single arm should be more than enough to handle the load, and second I have enough problem getting on and off of a lawn tractor the way it is alone blocking both sides with more obstacles, and one less cylinder to buy and plumb.
I'm only looking for not even double that much lift. So putting a arm on the other side would increase the lift to what i need right??
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
2021 Vermeer STR48 Hydraulic Trencher Attachment (A64912)
2021 Vermeer STR48...
TWO PALLETS OF HOSES AND EXTENSION CORDS/LIGHTS (A67714)
TWO PALLETS OF...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
PALLET OF ANCHORS (A68842)
PALLET OF ANCHORS...
