Need help deciding on a grapple
   / Need help deciding on a grapple #111
that's a good point CJONE.. I will likely purchase an auger in the future, does your auger run good on 3/8" hose? I might save my self the headache of a redo and run 1/2" if necessary to run a hydraulic motor more effectively.
Runs fine on 3/8", the 1/2" would be better for more than 10gpm or if the auger motor was a gear type. The geroller style will handle alot of backpressure, the gear will not. If you notice the poppet in you 1/2" quickcoupler is about the same as 3/8" hose so there is benifit to 1/2" but not much. I have the option of changing at anytime so no big deal for me.CJ
   / Need help deciding on a grapple #112
I just don't see the need for one to open wider than this:
View attachment 343884View attachment 343885View attachment 343886View attachment 343887
If it opened wider, the lid would have to be taller and the bottom tines would have to extend out further from the tractor, which would extend the tractor's center of gravity and lessen the lift capacity.
This would be a disadvantage, especially when pinching logs or heavy debris with a small compact tractor.......maybe not so much with a larger tractor.
With more opening it gets the tines away from your head when loading the grapple by hand. [see pics] Wich I do with firewood and to be able to grab larger objects like a stump. The stumps are the biggest problem, I know you don't mess with stuff like that with most compacts but as you know the Kioti has very good lift capacity and I use mine alot for this. I was told by the gent I talked to yesterday you had/have a DK40 so you know what it will pick. With a skidsteer grapple that is in the 800-1k range I loose more lift than I want. As far as the width of the grapple, when digging trees out the wider grapples put too much stress on the loader when popping roots with the edge, even the bucket IMHO is too wide to grub roots with. So after renting a wide one I guess I am the first one to admit it was too wide for my needs. CJ
   / Need help deciding on a grapple #113
Yes, the local hydraulic shops are often very, very expensive. Buy on line and go to the local shops for the odd fittings you want to eyeball. Sorry if any of you own a hydraulic shop. They seem to list things at x5 the online price and then give you a break to x3 the price. Just my $0.02
Tom check with a dedicated shop that deals with industrial accounts, they will have better pricing than a automotive shop that carries hyd hose. Also many online shops carry lower quality hose with less impulse ratings, import hose is considerably less$$ but from experience alot of it does not hold up in the extreme applications we have. You are right about the discounts, I can tell you any price I want then discount it. We mark up from cost and that is a fair way to do it. Most are surprised when they come in. CJ
   / Need help deciding on a grapple #114
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343884"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343885"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343886"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343887"/>
Good points but lift capacity would only be an issue for smaller tractors. A bigger version of your Light Duty for 40+HP CUTs would not suffer. My 48 Millonzi has a 46" opening which is useful for collecting brush and also for big stumps. Maybe use 3/8 mild or high strength steel but keep the single wide lid and the removable slats.
   / Need help deciding on a grapple #115
I agree with you for a tractor like the small 22 HP 1400 lb lift unit that you show. You make a good point at the end, larger tractors may be able to take advantage of the larger opening while staying with the narrower grapple.
To me this "which is the best grapple?" question is kind of like asking "which is the best bucket for my excavator?". My answer to the excavator question would be "it depends what you are wanting to do with it".
Narrow L bottoms have an advantage of maximum lift per lb of grapple weight and per dollar spent. And of best digging ability for small to medium machines.
Wide L bottom grapples have an advantage of maximum total volume capacity and maximum cleanup swath. Think storm cleanup or post dozer cleanup.
Rake grapples have an advantage of forward and back raking, with better root grubbing ability.
So my answer to the question about which is the best grapple would be "it depends what you are wanting to do with it".
Thanks for the info... I will price the 1/2" and if it's not a whole lot more ill upgrade
   / Need help deciding on a grapple #117
I agree with you for a tractor like the small 22 HP 1400 lb lift unit that you show. You make a good point at the end, larger tractors may be able to take advantage of the larger opening while staying with the narrower grapple. To me this "which is the best grapple?" question is kind of like asking "which is the best bucket for my excavator?". My answer to the excavator question would be "it depends what you are wanting to do with it". Narrow L bottoms have an advantage of maximum lift per lb of grapple weight and per dollar spent. And of best digging ability for small to medium machines. Wide L bottom grapples have an advantage of maximum total volume capacity and maximum cleanup swath. Think storm cleanup or post dozer cleanup. Rake grapples have an advantage of forward and back raking, with better root grubbing ability. So my answer to the question about which is the best grapple would be "it depends what you are wanting to do with it".
Very well stated tom.
   / Need help deciding on a grapple #118
Good point IT, as you get into the larger CUTs, the difference in weight between narrow/wide or smaller opening/bigger opening is almost irrelevant.
   / Need help deciding on a grapple #119
I just don't see the need for one to open wider than this: I do, brush isn't very heavy, if it will grab more, it takes less time to move it.
Not true, there is another way to make a wider opening, keeping the same bottom tine length.
Raise the pivot point and extend the top tines back down to the lower tines.
Notice how much higher above the SSQA, the top lid pivot rod is, compared to yours.
Show this to your design engineer for the next heavy duty wicked big mouth grapple! :D :thumbsup:
   / Need help deciding on a grapple #120
That setup is so bad asss looking. Very nice. Always impressed with your grapples.
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
159119 (A60430)
159119 (A60430)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 1025R (A53317)
John Deere 1025R...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
