Buying Advice Need an all purpose machine.
/ Need an all purpose machine. #21
how about something from Ariens? Something from the S or GT series.
/ Need an all purpose machine. #23
Another option would be a Cub Cadet SGT (Super Garden Tractor) or a GT3000 series (the newer version of the SGT).
We got a GT3200 this spring with ~600 hours for $4k from a dealer. It has a 60" deck, plow and blower.
You can get an 18xx SGT for under $2000 with a deck, plow and blower if you look, but parts may be hard to find.
EDIT: Like this one: http://rochester.craigslist.org/grd/2594320061.html
IMO the GT3200 we have is comparable to a Deere 400 (shaft driven implements, diff lock, heavy transmission, hydro deck/attachment lift, 3pt or sleeve hitch available). I think the implements (plow and blower at least) are made by the same company.
The SGT tractors are comparable to a 300 series Deere and will be similar to the Cub Cadet GT3000 series, but will have belt drive implements rather than shaft driven ones.
When I was looking, I also saw the Case/Ingersoll 446 was similar, but with lots of hours.
Aaron Z
They'd be good mowing machines, but neither of those could accept a loader
Looks like a 318 with a loader to me.
/ Need an all purpose machine. #25
/ Need an all purpose machine. #26
I had a 420, with 60" mover, snow blade, snow blower, wheel weights, and 3 pt hitch (never had anything to go on the 3 pt hitch), did a good job, cost me $5,000 10 years ago, traded it after about 8 years in on a 770 and got $3,000, and, 420 will accept the JD 44 loader, but those loaders are hard to find used, and cost a lot!
A 425 might be better one to look at, they can use a JD 40 loader, same as above on the 44 loader, used, expensive, and hard to find, but, have plenty of options for decks, blades, blowers, and the engine is water cooled, others you have mentioned are air cooled, differntial lock, like 420 and 430, and the 425 can have the 540 rear PTO, others mentioned, 420, 430, could have a rear 2000 PTO, the 540 could be used for a small rotary cutter,
But, you really need a small 5x8 trailer for hauling a small tractor with deck and other attachments, around, Tractor Supply have good prices on trailers, with fold down gates,
Use the bed of your truck for hauling other things you might need, string trimmer, etc.,
Having said all that, with the 5 acre lot, might want consider a 4wd tractor, like the 770's little brother the 670, with 4wd, 18 hp, but wouldn't fit on 5x8 trailer,
/ Need an all purpose machine. #27
A 670 was my first tractor...great little machine...and could even be used on those 1/4 acre lots with a mid-mount mower.
But even an older CUT like a 670 is probably going to exceed Pele's $2000 budget.
/ Need an all purpose machine. #28
A JD 420, 425, 445, or 455 would make a great choice. The problem with your thinking is that attachments are darn expensive and hard to find. One's with a rear 3ph are the rarest. Here's what you can expect to pay for attachments:
Loader $1200 - $2000
Scraper blade full setup $500
Snow blower full setup $800 - $1500
3ph - $400
rear pto (its an option) - very rare after market - $800
Weights and chains (these are must with any non-wheeled attachment) - $300
So, when setup with a loader and 3PH, you'll have well over $5K in that tractor. If and that's a BIF IF you can find the attachments when you are ready for them.
Sorry to say, but you'll never get to something very useful with a budget of only $2000. You are just wishing for the impractical. You would be smarter to look for a 750, 755, 720, or 770 with a loader. Then you'd have a lot more tractor, and these are around for about $5K.
Deere 670 is WAY too big to keep around here.
Maybe I should just go out and get a brand new Deere 6030 tractor and a Combine. I dunno what a combine does, I just know they're used on farms and it's something way more than I need.
I think you guys think I need way more tractor than I really do. Maybe it's the 5 acres bit that's doing it.
There's 5 acres, but most of it is woods. There's only about two acres cleared for a house. That two acres gets filled with weeds and I have to pick ticks off of myself every time I go there. I usually drive my wife's little Nissan Altima over the weeds though. I could probably take it out with a regular mower, but the bush hog would probably be faster. There's about 200 ft of dirt/gravel driveway leading up to the clearing.
I was thinking the Front End Loader would be useful for clearing snow and spreading gravel on my driveway. Maybe helping move mulch and stuff for gardening and putting heavy stuff like engine blocks, gearboxes, and rear ends in the back of my truck.
/ Need an all purpose machine. #30
Pele,
Perhaps we are not used to your way of thinkin.... :laughing: I'd use that as an excuse to get as Tim the Toolman Taylor says: "More Power." But I certainly understand budgetary constraints and storage.
Good Luck on your search.
Bart
/ Need an all purpose machine. #31
Just go to craigslist and search "garden tractor" in your area. Here's what came up in my area on the first page of the search
garden tractor on SearchTempest
Pele,
Bart
It ain't my decision entirely. The boss has a say in it too.
Unfortunately, she gets two votes in this family, hence the need for hydraulic deck lift and blade lift options.
She's due in March, so she'll need all the help she can get come snow clearing time.
/ Need an all purpose machine. #33
Having read all of the thread you need to increase the budget or decrease your expectation dramatically. Consider financing what you really wan't if need be.
/ Need an all purpose machine. #34
it really seems that anything bigger than your typical happy-homeowner garden tractor is just overkill for what the OP wants to do. he has a small trailer, has to store it in backyard toolshed, and has a garden tractor budget. other than the occasional bushhogging at a remote property, he is only mowing a 1/2 acre total, and pushing snow off a sidewalk; a job any home depot/sears/lowes lawn tractor could do. i guess if the OP is really set on a "tractor" that can accept a loader/3pt attachments, etc, a 9n/8n is about the only thing in his price range; but a tractor that size is wayyyyy too big fior mowing a 1/2 acre and working on sidewalks
/ Need an all purpose machine. #35
They are rare, but I think there are some older small tractors that might fill most of Pele's needs, and come within, or close to, his budget. How about the Bolens/Iseki tractors, or the older, smaller Mitsubishi Satoh tractors? I believe there were some Simplicity garden tractors that took a loader. Aren't there also some early small Kubotas and Yanmars that might be in the ballpark? Someone also mentioned Case/Ingersoll. Those were very rugged small tractors.
Pele - Don't give up easily. Check all the sources you can for older, smaller bargain tractors. You may find something that has lived an easy life, and has plenty of wear left, in your price range. On the older machines, you will likely have to do your own mechanic work, and finding parts will be a challenge. There are plenty of guys that do that as a hobby.
Also, if you haven't already, scout through some of the other sections of TBN for information on the tractors that I and others have mentioned.
Good luck in your quest!
/ Need an all purpose machine. #36
Go back to my first response...I suggested you get an old lawn tractor or a self propelled walk behind mower. Either would suffice for those 1/4 acre lots.
You came to TBN and asked a question. You got very resonable answers...but apparently you don't like the responses and resort to a wise ***** comment.
It's not our problem you can't afford what you want...nor is it our problem if you can't swing a loan.
See, this is what I'm looking for...
Here's the rub on older tractors for me... How do I figure out if it's a good workhorse or a collector's item? If you had a 1957 Chevy pickup, would you toss a load of firewood or scrap metal into the bed?
Also... I see lots of newer tractors boasting 20+ HP two and three cylinder engines. Then I see older ones with single cylinder 8-12 HP. Are they really up to the task? I mean, my push mower is 6.5 HP and it's just swinging a 21 inch blade and pushing a 30 lb aluminum deck... 13 horse should move two blades and push a 60 lbs worth of mower... But this is spinning much bigger blades than the push mower and it's pushing 600+ lbs worth of tractor plus 180 lbs of me on it.
When I see a 20 HP riding mower at Home Depot that takes no implements and I see a compact Diesel with a cat 0 or 1 three point with 15 HP, it gets confusing.
Hey man, I didn't mean any offense. But I really haven't gotten answers to some of my questions... I don't mean any disrespect and I'm not trying to tick you off or anything.
Why aren't the small garden tractors adequate for my purposes.
If a bush hog won't fit on the cat 0 three point, then I can just use the mower deck. None of what's on the empty property is bigger than my fingers, belly mower should take care of it.
I don't know why you're getting all defensive. I never said my budget was your problem. What I did say was, I think y'all were recommending much larger machines than was necessary without saying why I need such a big machine.
/ Need an all purpose machine. #39
The reason you aren't getting any answers is that there really is very very little that fits yours needs in your budget. You aren't likely to find an older machine that's small enough with a loader in your budget. You'd be better off buying a used lawn tractor for a few hundred dollars and then getting a big tractor with a loader for the other stuff.. Reason? There a a lot more old real tractors around with loaders.
I have a friend who bought a ford 4000 (like 50 hp or so) with loader for $3500. Now it's a beast and the loader is far from modern. But, it lifts and hauls, bush hogs like crazy, and will go just about any where even though it's only 2 wheel drive.
You aren't going to find a smalll used garden tractor with loader that's worth bringing home for $2000. Probably not even for $4000. Just reality. But, keep looking. Miracles do happen every day.
/ Need an all purpose machine. #40
Probably because you want to run a rotary cutter and add a front end loader. Most lawn tractors don't have that capability (lacking hydraulics, PTO and 3PH). The ones that do have those capabilities are beyond your budget, for the most part.
I ruined a nice old Wheel Horse doing that...better off hiring someone to make the first cut, then maintain it.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59912)
2020 KENWORTH T680...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
