Need advice on my kioti
   / Need advice on my kioti #41
that implies the transmission slips. compare that effect to a geared tractor, the transmission don't slip, and just bogs down the engine instead if you're in too high a gear.. automatic transmissions have been designed for decades without slipping but a tiny bit..
No, he meant the ground speed varies because you adjust how far you are pushing the pedal with your foot. To keep the rpms constant and not bogging down, sometimes you have to back off as you head up a hill, and vehicle ground speed slows.
   / Need advice on my kioti #42
Well, I did what you ask me to do and sent a request to change my op title to " I need advice on my Kioti " now I wait and see if it changes.
OK. Thanks for following my suggestion- I was not aware you had done so, because you did not say you had until now.
As far as your tractor's performance, your question is a very subjective one and requires specific information about the hills steepness/grade and length, and how you approach it, what implements you might be carrying, etc.
Most of the posters have concluded your tractor is performing as intended and the issue is the range selection needs to be in a different 'gear' other than high range. This is NOT a tractor error or defect, (unless your machine's relief valve settings are below specs), regardless, you need to chose the right range selection, which is most likely to be M or possibly even L, but definitely NOT H.
What some seem to not comprehend is that an HST tractor is NOT a gear tractor and will not perform the same as one. It doesn't make one better or worse, just like a gear truck or car is no better than a automatic transmission truck or car. They are choices available and personal ones at that.
   / Need advice on my kioti #43
I will give you an idea of how high the hills are. One hill is 1 mile long and I am going from flat ground to 1300 feet to the top. 2nd hill is 1/4 of a mile going from flat to about 500 feet and there are a few not so high in between. Now if you can find a hill around your area that is close to the same height and distance then you tell me how your machine performs as I am curious.
If I'm reading these numbers right, ~25% grade, ~38% grade. :eek:
MY barely 3k lb 35 hp HST would struggle with these unloaded and in M range. That said, spinning tires is a common occurrence when I'm in the right range for the task ... and on level ground.
btw, you guys who squabble a bit here, ... have at it. I like you both and don't think you'll change that no matter what you say or don't say to each other. :) t o g
   / Need advice on my kioti #44
My TC45DA's would struggle badly climbing hills, it was like the pump was just plain weak.. And they could have very well been weak, I found them to be weak lifting with the loader as well.
This is my fourth hydro tractor and I have noticed a difference in each one of them. NH, JD and Massey.
When you compare two tractors, one with less engine HP than the other and the tractor with the least amount has more PTO HP, that tells me the hydro system in the lower engine HP tractor has a better system and It's been proven to me.
I just did a comparison of my 22.5 engine HP 18.9PTO Massey compared to X name brand 24.5 engine HP 16.2PTO HP, I drove the X name brand with nothing but a loader attached around there large lot with a couple of small hills and noticed immediately the tractor was weaker than what I'm use to with my lower engine HP tractor, the loader specs were more evidence of a weaker hydro system.
Are all hydrostatic tractors similar, YES, are they all the same NO, and that is why some people either like their hydro tractor or they don't..
   / Need advice on my kioti #45
.. I just did a comparison of my 22.5 engine HP 18.9PTO Massey compared to X name brand 24.5 engine HP 16.2PTO HP, I drove the X name brand with nothing but a loader attached around there large lot with a couple of small hills and noticed immediately the tractor was weaker than what I'm use to with my lower engine HP tractor, the loader specs were more evidence of a weaker hydro system.
My smallest tractor (1.1L, 26 hp) has but two ranges, and like many I wish it had a Medium as often as L seems too slow and H too weak. What might make hp and pulling/climbing power seem oddly disproportionate between makes/models is the probability that o'all gearing (torque motor to final drive) is likely quite different and thus why we're seeing such noticeable disparity.
My thanks to the mods for helping our guy with a title revision. I dearly love my Mechron 2200 and wish Kioti's tractors had color options as well. ;)
   / Need advice on my kioti #46
I saw a used DX33 while I was there, three range and adjustable draft arms, something you don't see anymore in a 33hp tractor, it was well worth what they were asking for it..
   / Need advice on my kioti #47
Exactly.
Weight and gearing may have a good bit to do with these differences in high range.
   / Need advice on my kioti #48
Thread pruned. No notices sent. Please continue the original discussion.... :cool:
   / Need advice on my kioti #49
1300 feet up in 1 mile is a 4:1 incline. For every 4' forward you are going 1' up.
A 1:1 slope is 45 degrees, and 100% grade.
A 2:1 slope is 22.5 degrees, and a 50% grade.
A 4:1 slope is 11.25 degrees, and a 25% grade.
That is a very steep angle and grade to try to go up in high range and hold speed.
One thing I didn't see you write was what you are doing with the throttle. Several people asked if you have it at full throttle or not, but I did not see the answer.
utv cart Honda (A56857)
utv cart Honda...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2017 KUBOTA SVL75-2 SKID STEER (A52707)
2017 KUBOTA...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
