Need Advice LA723
/ Need Advice LA723 #1
Jason H.
I have a 3130 DT with a LA723. I have a requirement to lift pallets of bagged powder at 2,000 lbs per pallet. I only need to be able to lift them about 2-3 feet high on to a bobcat trailer.
I need a performance curve based on distance from the pin and lifting height. So...my question
If the LA723 is rated at 1600 lbs lifting and I would guess thats all the way up. Can I lift 2,000 a couple feet?? I know I'll need my bushhog on the rear to keep her planted.
Thanks in advance.
/ Need Advice LA723 #2
It thakes the same amount of force whether your lifting it 2ft or 10ft. Plus a pallet will be farther out than your bucket would be so it would be harder to lift than the same amount of weight in the bucket.
/ Need Advice LA723 #5
I second the motion on it will not lift I too have tried it... It may get them up a few inches... but the "EXPERIMENT" I went through is that the back tire will come up off the ground....
/ Need Advice LA723 #6
Thanks in advance.
Jason , I have a L3400, w/ FEL and woods 80 backhoe. This weekend I was moving boulders and had a heck of a time w/ one large one. I could only get it 4" off the ground. Out of curiosity what was your RPM's that you were running. I found my bucket couldn't lift it but the tractor was able to move it
thanks
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
Morbark M12D (A63689)
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
