Need Advice LA723
/ Need Advice LA723 #1
Jason H.
I have a 3130 DT with a LA723. I have a requirement to lift pallets of bagged powder at 2,000 lbs per pallet. I only need to be able to lift them about 2-3 feet high on to a bobcat trailer.
I need a performance curve based on distance from the pin and lifting height. So...my question
If the LA723 is rated at 1600 lbs lifting and I would guess thats all the way up. Can I lift 2,000 a couple feet?? I know I'll need my bushhog on the rear to keep her planted.
Thanks in advance.
/ Need Advice LA723 #2
It thakes the same amount of force whether your lifting it 2ft or 10ft. Plus a pallet will be farther out than your bucket would be so it would be harder to lift than the same amount of weight in the bucket.
/ Need Advice LA723 #5
I second the motion on it will not lift I too have tried it... It may get them up a few inches... but the "EXPERIMENT" I went through is that the back tire will come up off the ground....
/ Need Advice LA723 #6
Thanks in advance.
Jason , I have a L3400, w/ FEL and woods 80 backhoe. This weekend I was moving boulders and had a heck of a time w/ one large one. I could only get it 4" off the ground. Out of curiosity what was your RPM's that you were running. I found my bucket couldn't lift it but the tractor was able to move it
thanks
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
213135 (A64276)
213135 (A64276)
2022 EZ-GO ELITE...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
