Need Advice: Hooking up TSC Log Splitter to 2305
   / Need Advice: Hooking up TSC Log Splitter to 2305 #1
JohnnyTractor
Southeastern Wisconsin
John Deere X485
Well, after reading just about every post known to man /forums/images/graemlins/smile.gif on log splitters, I pulled the trigger on the TSC 3pt splitter. $645 was a good price, and I can wait for the long cycle times.
From what I can see, there is a cap on the hydraulic pump that looks like it could be replaced with an in/out feed; but I'm guessing.
Here's a some questions:
1. Can I hook up to the SCV fittings for the FEL with the loader off? If so, how do I know which color is which?
2. I've read a lot of references to the Power Beyond kit, but could not find any details. Is there a web site? Is this a JD factory offering?
3. Will I need to worry about adding more fluid after tapping in the log splitter?
4. Is there a kit for my 2305 that will bring hydraulic couplers to the rear of the tractor?
   / Need Advice: Hooking up TSC Log Splitter to 2305 #2
Sir,
I have a TSC tph splitter. I set it beside an upright on my tractor shed and secure it with a chain. I don't have to remove my backhoe. I put some quick couplings on the hoses to the splitter and hooked them to the fel controls on my Mahindra 2810. I use a bungee cord to hold the lever open. I split wood for 35 years with a maul. I love my TSC splitter. Good luck.
Mrpoppy
   / Need Advice: Hooking up TSC Log Splitter to 2305 #3
<font color="red"> 1. Can I hook up to the SCV fittings for the FEL with the loader off? If so, how do I know which color is which? </font>
Sure you can, You can even leave the FEL on, just disconnect the lift circuit and tie the joystick back with a bungee. Your loader manual will tell you witch colors are for what circuit.
<font color="red"> 2. I've read a lot of references to the Power Beyond kit, but could not find any details. Is there a web site? Is this a JD factory offering? </font>
The PowerBeyond kit is a JD offering for the larger tractors, I don't think it's available for the 2305, I know it was not for the 2210.
<font color="red"> 3. Will I need to worry about adding more fluid after tapping in the log splitter? </font>
Maybe a little, it depends on the size cylinder it has, and how much hose you end up adding.
<font color="red"> 4. Is there a kit for my 2305 that will bring hydraulic couplers to the rear of the tractor? </font>
No, but you can make up a kit easily, just need the right lengh hoses, some QD (quick disconect) couplings, and some zip ties. Find a hydraulic shop in your area and they can hook you up /forums/images/graemlins/grin.gif
   / Need Advice: Hooking up TSC Log Splitter to 2305 #4
My brotherlaw bought one and the hydraulics were to slow on his 790 it puts out 5.6 gals a minute. People he talked to had to use a big tractor that put out alot of gals per minute. He returned his to tsc and picked up one with a engine on it. good luck
Forget it. I took it back and purchased the 27 ton tow behind v/h with the honda motor. As soon as I got it home I was splitting wood! /forums/images/graemlins/grin.gif
   / Need Advice: Hooking up TSC Log Splitter to 2305 #6
Well, bummer. I was hoping to find how it would work, but still, glad you are splitting wood, and that you have a great tractor to tow the splitter around with. You can also continue to use the tractor to feed the hungry splitter and carry away the spoils.
Cliff
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
Toro (A56857)
Toro (A56857)
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
Westerndorf 10' Box Blade (A59814)
Westerndorf 10'...
