Need a recommendation: log splitters
/ Need a recommendation: log splitters #41
Splitfire
The Splitfire I use has about a 4 second cycle time. makes for some fast splitting if the wood grain is straight, which most is. The only problem is to keeping up with the splitter it takes two people to move the wood.
/ Need a recommendation: log splitters #42
15.4 GPM pump on tractor running wide open will keep three men busy and the wedge never stops :)
/ Need a recommendation: log splitters #43
Our biggest pieces are sometimes 20-24" diameter and are too heavy to lift so vertical mode is a must.
This is a typical pile of wood by fall.
/ Need a recommendation: log splitters #44
I just have a cheap "homeowner grade" splitter myself. It will go vertical or horizontal, but I've never tried it in the vertical mode. Like others have said, I need to work while standing and not bending over and wrestling rounds on the ground to split. Picking a round up off the ground to set on the table isn't near as bad as long term bending over to work the splits on the ground. Most of the time I have the pre cut rounds sitting in my fel bucket at a comfortable height next to me while I'm splitting on the small table. Then I toss the splits into either my garden cart, or hopefully into an IBC tote frame. If I'm lucky and have access to an empty IBC tote, then that will be the last time I have to handle the wood until it's time to carry it from the garage into the house to burn it (I'm fortunate enough to be able to bring a tote all the way into my garage and stage it inside to pick wood from).
My splitter. Nothing to get excited about, but it works...
/ Need a recommendation: log splitters #45
Found another picture of my splitter. I bolted on some plywood to the sides to hold the wood that I'm not splitting. I split it in half, put one half on the plywood, work the other half, then work that first half.
If it's a really big round, I might drop the half to the ground, and then split the other half and put that quarter on the plywood. I try to avoid messing with really big rounds, they wear me out.
/ Need a recommendation: log splitters #46
I can’t lift but have a long reach so bringing the rounds to the splitter with the loader and then reach and roll with splitter vertical works well for me…
A few are so big I could never lift and it’s all I can do to roll but the 22ton spitter takes all the Coast Oak I can get under the wedge.
/ Need a recommendation: log splitters #47
We have a round about 10" high that we squat on and work the machine vertical. Have a foam pad. My wife and I tag team. One person throws the wood and keeps unsplit close at hand for the other who is doing the splitting.
Repeated lifting of 100 pound (or even 50 pound) rounds are not a good solution for us.
/ Need a recommendation: log splitters #48
I also sit on a round when splitting vertical. I also keep an axe handy if you have one that is a little stringy. It seems easier to roll a large round to the splitter and the flip it on end and rock it into position than noodling or lifting a heavy one up with the end loader.
/ Need a recommendation: log splitters #49
So, Beowulf, did you ever decide on a new log splitter?
The new log splitter bug has hit me with a vengeance. Really liking the looks of Wolfe Ridge splitters. Maybe a 28 pro model. Eastonmade Ultra looks really nice as well. Both are overkill for my needs, but I believe I want a quality splitter, that will last the rest of my life.
Split fire has a new small verticals model. 1165v that looks really nice also. Decisions, decisions……
/ Need a recommendation: log splitters #50
He said on page 2 of the posts he pulled the trigger on a Champion 27.
We have just finished putting another year on ours. Filled 12 totes stacked over the top so 4 cord. It didn't seem to care at all no issues. Engine oil change is a nothingburger, only about 1qt. Usually starts first pull.
The Wolf Ridge are beautiful and look well made, but their cost is kind of out there. I think their cheaper horizontal units are getting close to the cost of an entire import firewood processor with a lot of options that will saw for you and has conveyors.
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
