Looking for log splitter recommendation
/ Looking for log splitter recommendation #21
I got 22T Dirty Hands from local Tractor Supply. It's about 5 years old by now and no problems at all. Splits everything I feed it.
/ Looking for log splitter recommendation #22
I up graded my old TW-1 for the newer model just two years ago.
I wanted the faster cycle times. I'm NOT DISAPPOINTED.
With a removable 4-way wedge and a run off table that I made from grating. It has all I need.
I'll get it out next month again. The log pile is waiting, and the dry wood that has been stacked in the work area is mostly ashes now ;-)
eta
I am also 70 yoa and not in a hurry, but waiting on the return stroke just started to bug me.
ps A 3pt mounted splitter would not suit me at all. I use the loader bucket and the carry all to move both rounds and splits all the while I'm splitting. Having a carry all full of rounds next to the splitter rail and at height is a real back saver!
/ Looking for log splitter recommendation #23
Holy moly. I am amazed at what people spend on stuff. I ”only” do about 10-12 cords a year for my place. I bought a 27T Black Diamond splitter years ago at the local ranch store new on a great sale for $450 With a Kohler motor. I have a Stihl MS291 that traded in a stihl brush cutter straight across for in 2005 after I got done with scrub brush. If you are just doing 2 cords, buy the cheapest one you are comfortable with since it will only run about a tank of gas a year.
Holy moly. I am amazed at what people spend on stuff. ....
That is the problem, the cheap ones are not ergonomic for me and I find them uncomfortable to run. I have been looking at them and standing in operating position I find something typically is in my way, most times it is the wheel/tire. I also find most of the cheaper ones to be too low for me. Renting a few of them has re-enforced my thinking on this. I am 6'1" and have a bad back and I can't be leaning over operating the thing for any length of time. I am thinking with a 3pt unit I can raise it up to the height I am comfortable with, or drop it down to roll a heavy log onto it. My wife is about 1.5' shorter than I am and it would help to be able to adjust the height to be where it was comfortable for her as well. I can throw the splits into the RTV900, take them to where I want them and then hit the hydraulic dump lever to dump the load.
/ Looking for log splitter recommendation #25
I hear you on the ergonomics.. I have been renting a Split-Fire this year and the table height is a good fit for my height (5'-10"). Neighbor who is 6'-2" also ran a lot of rounds and ordered one for his business.
This year my grandaughter ran the hydraulic controls while I loaded logs and took the splits off of the table.
/ Looking for log splitter recommendation #26
If the splitter is a bit low, maybe get larger tires/wheels or have it on blocks? It is good you are taking ergonomics into consideration though. (y)
/ Looking for log splitter recommendation #27
My tractor has a hydraulic flow of 16.9 gpm
Kioti quotes "total flow" in their specs. But in reality you will only get about 10 gpm at the remotes. The hydraulic system on most modern CUTS has two pumps. One runs the power steering and maybe a low flow item like the PTO clutch. The other one runs the loader, remotes and 3pt hitch. Usually on a machine this size the remotes get about 10 gpm and the steering circuit gets the rest. My 37hp Branson is like that.
If you had a real 16 gpm available at the remotes then you could probably do ok without a PTO pump. The system pressure will be less than the typical pressures that a stand alone splitter with two speed pump puts out in the low flow/high pressure speed. But if the cylinder is large enough it'd probably do ok for most types of wood. However at 10 gpm it's likely to be slow. Keep in mind that you'll need to run the engine at PTO RPM to get that 10 gpm.
You'll probably be happier with a PTO pump to run the splitter, except when you're putting the splitter on or taking it off the tractor.
I sometimes split some difficult to split species like Eucalyptus so I got a splitter with a 4.5" cylinder and high pressure. Most splitter ton ratings are optimistic (and some are flat out lies) but my splitter's 28 ton claim is pretty close to the calculated value.
/ Looking for log splitter recommendation #28
My delima too; I've been here since 2001 and have-had my mostly replaced grey market splitter since 2003; I want a new splitter so badly, but I just don't want to dump the money into it...the splittlers I look-at are >$3K....😳
So, I extended the tounge (tailgate clearance), I park the splitter on 4x4s (to level and increase the height), I prevent the ram from withdrawing past 17" (to speed up cycle times). I run an over-sized filter...
/ Looking for log splitter recommendation #29
I'm fortunate to have a wife that likes to help splitting wood. I handle the wood while she runs the lever on the valve.
Pricing is my dilemma as well. I don't have a powered log splitter at the moment. If price was no object I would get a Timberwolf or American CLS and be done with it. I do have a 16lb splitting maul that works very well, but I don't have to swing it too many times nowadays before my back says that maybe the Timberwolf is looking cheap.
1604 (A57192)
1604 (A57192)
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
