Need a pto log splitter guru for advice J_J?
   / Need a pto log splitter guru for advice J_J? #82
If using a 4 in cyl, with 2 in shaft, and 2000 psi, the push force will be about 12.5 T.
Using 4.4 GPM,
Extend speed = 18.14 sec
retract speed = 13.33 sec
Total cycle time = 31.79 sec
If using the fast extend valve, the cycle times will be.
Extend 2.857 sec
Retract = 13.33 sec
Total cycle time - 16.18 sec
   / Need a pto log splitter guru for advice J_J? #83
Has anyone ask themselves why the cyl manufacturers don't make a log splitter cyl with a larger shaft. It would speed the retract time, and decrease the retract force about 3.1 T
For instance,
4 in cyl, 2 in shaft, 10 GPM
Extend speed 7.74
Retract speed = 5.85
Total cycle time = 13.59 sec
4 in cyl, 3 in shaft
Extend = 7.74 sec
Retract = 3.42 sec
Total cycle time = 11.16 sec
   / Need a pto log splitter guru for advice J_J? #84
I have always wondered about that myself.
You dont need much force retracting. And that is what I seem to wait on the most. I usually have the next peice ready and waiting for the ram to get out of the way.
I have often though I would build one if I could get my hands on such a cylinder. I know some heavy-equipment cylinders have oversized rods.
Example: The Ford 4500 BH bucket cylinder is a 3.5" cylinder with a 3" rod diameter:D It would be nice if I could find one like that in a 4" or 4.5" at a good price.:thumbsup:
PhysAssist,
Have you even read this thread?
   / Need a pto log splitter guru for advice J_J? #86
PhysAssist,
Since that Heath kit splitter is pretty old, and the engine is probably bad, I would recommend going with a new 3pt splitter and using the fast extend valve. Either keep or sell the valve on the 3pt, and replace it with the Prince LSR 3060.
   / Need a pto log splitter guru for advice J_J? #87
JJ,
I appreciate your time and advice- and I woulda got back to ya sooner, but I needed knee surgery.
I'm doing good now that it's over- so it's time to get the splitter build moving.
Thanks again,
You have clarified my understanding of the situation.
Thomas
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2013 Honda CR-Z Hatchback (A50324)
2013 Honda CR-Z...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
