Need a measurement
/ Need a measurement #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
Hi all.
I'm looking to weld together a 3 point receiver hitch contraption this weekend. However, I need an approximate measurement for the vertical distance from the lower 3 point arms up to the top link. The only 3ph implement I have right now is my finish mower, and with the floating attachment points, I can't take an accurate measurement. If someone could measure their blade, rake, etc, I would much appreciate it!
Thanks
Todd
/ Need a measurement #2
I don't have an address for you.. but do a search for asae standards for the cat 1 hitch.. it will be listed in a diagram.. all the geometry and measurements.. lacking that.. measure one of your other implements if you have any.
Soundguy
/ Need a measurement #3
Here is a nice page from SpeeCo, but it doesn't list the vertical distance.
3 point dimensions
/ Need a measurement #5
If you haven't already made it (this is Monday as I type this), I've made a couple for friends based on the averages of some of my implements and they've worked fine. The numbers I used were 14 5/8" for the height and 27 1/8" for the width. Actually, I just go on the outside of the soap line I mark at 14 1/2" and 27" but that seems to be close enough. I don't know how this matches the the actual specs, but it works well on every tractor I've tried it on (even with quick attach).
Thanks for the help guys!
I didn't get started on it this weekend as some other things came up. Now I can hit the ground running!
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65579)
IMPORTANT PLEASE...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
