Need 1538 3 point top link dimensions
/ Need 1538 3 point top link dimensions #1
LowellBen
Bronze Member
2015 Mahindra 1538HST
When I bought my repo 1538, it was missing the top link of the 3 point. I thought 'Eh, I'll pick one up later".
Talked with local dealer and OMG - about $600 for the pieces not including the pins. Looks like Cub Cadet uses the same parts for their 3 point, but I'm not sure about ordering from a place called ereplacementparts - they were about $100 cheaper. Gonna call CC tomorrow.
Doing some more looking around, there are numerous places that sell Cat 1 top links for about $30 - but what length do I need?
Does anyone know what the minimum and maximum length is for the top link on their 1538 3 point?
Currently my 1538 has the back hoe on it and what I would like to obtain is a tilt blade to clean up the ditches along my driveway. Not sure if the 1538 can handle a 7' blade though.
Last year I worked the heck out of the back hoe cutting a good chunk of trail along the back side of our property. Thought about sending the pics to TractorbyNet, but figured I would get hammered about how unsafe it was to work on that steep of a slope. Had to put a sealed battery in the tractor cause battery acid was leaking out on the steep slopes.
Much thanks if anyone can provide the lengths for the top link.
Lowell
/ Need 1538 3 point top link dimensions #2
Swing by your dealer and measure one on a tractor on the lot.
That will let you know roughly what size you may need.
Some implements will need a different length then stock.
Thanks for the idea. Last time I was at dealer they only had one or two of the smaller tractors, but I guess if those tractors had a Cat 1 on them it should be the same. Not sure when I would get over there, they are 80 miles away.
/ Need 1538 3 point top link dimensions #4
The mid adjustment should be around 24"-25".
You should be able to figure out from that what will work for you.
19643038AG0 Adjuster 194.27
19643039000 Locknut 51.05
19643037BR0 Turnbuckle 154.77
19643041000 Adjuster 192.88
Total without tax + shipping to dealer 592.97
And then there was another about 30 for pins.
Thanks to Brian for replying with a mid-length - I can work with that. Northern Tool or Harbor Freight or Weaver's Compact Tractor Parts or a bunch of other suppliers for Cat 1 top links.
Silly me thinking that Mahindra was even on the same planet on the cost of these parts. A year or so ago I had to replace a starter. Think that was about 700 from the dealer. A forum member pointed me to a place in the UK that got it to me for about 250.
Thanks for the replies guys!
Lowell
/ Need 1538 3 point top link dimensions #7
Lowell
OMG. aftermarket here I come lol
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
JCB 3TS TELESKID (A65056)
JCB 3TS TELESKID...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A68842)
PALLET OF 2CYL GAS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2007 WESTERN STAR 4900 SB CRANE TRUCK (A67714)
2007 WESTERN STAR...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65057)
2023 WALLACE-THE...
