Need 1538 3 point top link dimensions
/ Need 1538 3 point top link dimensions #1
LowellBen
2015 Mahindra 1538HST
When I bought my repo 1538, it was missing the top link of the 3 point. I thought 'Eh, I'll pick one up later".
Talked with local dealer and OMG - about $600 for the pieces not including the pins. Looks like Cub Cadet uses the same parts for their 3 point, but I'm not sure about ordering from a place called ereplacementparts - they were about $100 cheaper. Gonna call CC tomorrow.
Doing some more looking around, there are numerous places that sell Cat 1 top links for about $30 - but what length do I need?
Does anyone know what the minimum and maximum length is for the top link on their 1538 3 point?
Currently my 1538 has the back hoe on it and what I would like to obtain is a tilt blade to clean up the ditches along my driveway. Not sure if the 1538 can handle a 7' blade though.
Last year I worked the heck out of the back hoe cutting a good chunk of trail along the back side of our property. Thought about sending the pics to TractorbyNet, but figured I would get hammered about how unsafe it was to work on that steep of a slope. Had to put a sealed battery in the tractor cause battery acid was leaking out on the steep slopes.
Much thanks if anyone can provide the lengths for the top link.
Lowell
/ Need 1538 3 point top link dimensions #2
Swing by your dealer and measure one on a tractor on the lot.
That will let you know roughly what size you may need.
Some implements will need a different length then stock.
Thanks for the idea. Last time I was at dealer they only had one or two of the smaller tractors, but I guess if those tractors had a Cat 1 on them it should be the same. Not sure when I would get over there, they are 80 miles away.
/ Need 1538 3 point top link dimensions #4
The mid adjustment should be around 24"-25".
You should be able to figure out from that what will work for you.
19643038AG0 Adjuster 194.27
19643039000 Locknut 51.05
19643037BR0 Turnbuckle 154.77
19643041000 Adjuster 192.88
Total without tax + shipping to dealer 592.97
And then there was another about 30 for pins.
Thanks to Brian for replying with a mid-length - I can work with that. Northern Tool or Harbor Freight or Weaver's Compact Tractor Parts or a bunch of other suppliers for Cat 1 top links.
Silly me thinking that Mahindra was even on the same planet on the cost of these parts. A year or so ago I had to replace a starter. Think that was about 700 from the dealer. A forum member pointed me to a place in the UK that got it to me for about 250.
Thanks for the replies guys!
Lowell
/ Need 1538 3 point top link dimensions #7
Lowell
OMG. aftermarket here I come lol
Club Car Emergency Cart (A64557)
Club Car Emergency...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
PALLET OF WHEEL SPACERS & WEIGHTS (A64278)
PALLET OF WHEEL...
2025 SGB20 20in Hydraulic Grapple Stump Bucket (A64553)
2025 SGB20 20in...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
