Narrowing Down my Choices
/ Narrowing Down my Choices #1
Hook
Milford, NJ
Kubota L3010
In about 1.5 months we're moving from 0.5 acres to 15 acres. I've been doing lots of research on tractors, but haven't been able to come to a final decision, as I wasn 't familiar enough with the property we're buying.
But I made another trip there today & I think I have a good grasp on what I have to do. I will be mowing about 4 acres on a regular basis. Another 2 acres is pasture, which I'll cut down once or twice a year. About an other acre is brush which I'll probably cut only once/year.
In addition, I will need to be a lot of work on abourt 1 acre of the ground before I reseed it. I'll need to fill some small "ravines", smooth the soil, put some good loam on it, etc.
Here's my thinking about a good tractor for me:
1) I really think the Kubota BX2200 will do all that I have listed above.
2) BUT, I think I should go up a notch, since I'll probably find more to do & I have plenty of space in the barn for a larger tractor.
Currently, I'm thinking of
- Kubota B7500 (or even B2410)
- NH TC21D (or even TC25D)
- Deere 4200
Any comments or suggestions on my thinking & these candidates?
--Hook
/ Narrowing Down my Choices #2
Its not that the BX won't handle it. Its how long will it take to do the work.
I too think you need a bigger tractor and it should be bigger than a B7500 IMHO.
Winnipeg, Manitoba
2001 BX2200 (26 hrs)
/ Narrowing Down my Choices #3
Hook,
I'd set my sights larger. With 4 acres to mow regularly, you would appreciate a 72" finish mower. For three acres of rough cutting (and another 8 acres of potential something), you would be better off with a 60" inch rotary cutter than a 48". This would require a 27/2910 in the Kubota line.
I have 11 acres. I finish mow 3, and rough mow 3 or 4 (with the rest being future potential). I originally bought a BX, but quickly traded it in for a B2910 with the size mowers stated above. I wouldnt want anything smaller. If anything, I would like something a little bigger, but not as big as the Kubota Grand L series. If I had it to do over, I would seriously consider the JD 4300 as a good size, but I wouldnt buy it.
/ Narrowing Down my Choices #4
Hook, like the other guys said, you can do it with the tractors you're considering, but of course you'll do it quicker and more comfortably with a bigger tractor. I used a B7100 for 4 years before moving up to the B2710.
Bird
/ Narrowing Down my Choices #5
You should try to move up to a tractor with three ranges if you are going to do much excavating work.
/ Narrowing Down my Choices #6
My suggestion is to get all you can afford. I mow and mow and mow and went from 4 hours on a rider to just over 2 on my B7500 with 60" MMM. A 7500 will handle all your chores.
Bluegrass, Pick It Up!
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
1993 Transcraft 38Ft Step Deck trailer (A64194)
1993 Transcraft...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
