Narrowed Meyer snow plow?
/ Narrowed Meyer snow plow? #1
Scaper
I live in the state of Delaware in New Castle Coun
New Holland 1030
Has anyone gone through narrowing a truck snow plow to fit a compact tractor? If so are there any precautions that I should be aware of. I would like to cut around 10 to 11" off each side of a 78" Meyer poly plow and use it on my BX2200 with a loader bucket mount. Mark
/ Narrowed Meyer snow plow? #2
Scraper,
I cut down a 96" truck plow down to 80" to fit my B2410. I just cut out the curved bracing on each end that follows the moldboard contour and moved it in 8" from each end, then wacked off what ever was left sticking out on each end. I also removed three of the five trip springs to make the plow trip when I felt it should. Mine is mounted in the bucket and I love this set-up. This set-up makes my plowing easy and I can have the use of just the bucket in about two minutes. I think if you do a search for "plow in the bucket" or "plow to bucket" another member here (Thomas) has some pics of his set-up. Mine is similar.
winchman
/ Narrowed Meyer snow plow? #3
You might want to check out the "Someone with a 4100 and 54" front blade" post in the JD owning and operating section. dj1701 had a meyers plow cut down for his 4115...
/ Narrowed Meyer snow plow? #4
Not quite understanding the size of your machine /forums/images/graemlins/frown.gif I ask why would you cut it down? I have a 20hp compact and it handles the 7' plow just fine. the width of my unit is 49" if I remember right.
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
John Deere 535 Round Baler (A63688)
John Deere 535...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
