Name this tractor
/ Name this tractor #1
ACDNate
Ocean Springs, MS
None Yet...
20HP with a collection of implements came up on craigslist. Seller claims it to be a 2007 model. Odd labeling that I can only assume is of chinese manufacturer descent. I've spoke with the sellers wife who doesn't know much about it, he's at work. Anyway take a peek at the pic and see if anyone recognizes it.
/ Name this tractor
Ah so it is a Jinma. Thanks! :thumbsup:
Smaller than I'm looking for but curiosity was getting the better of me.
/ Name this tractor #4
/ Name this tractor
They are including a 5ft box blade, 5ft finish mower, 5ft bushhog and boom pole. No mention of hours on it. Asking $5500.
Being a 2 wheel drive model, I don't hink it would meet my wish list. I need to move a decent amount of dirt/stone over the next year or so and really need a front end loader. From what I've gathered here I really need 4 wheel drive to use a front end loader, not to mention I don't know if a FEL is available for this tractor.
The Grill is labeled JM200, so I'm assuming it's a Jinma JM200
/ Name this tractor #8
Given that Sam's asks $5400 for a new one - depending upon the number of hours on that 2007 - you're kinda gettin' the implements for free.
And in my book, the JM200 front end is more suited for loader work than is the JM204. In fact, reputable dealers recommend taking the JM204 out of 4wd when doing aggressive loader work. You'll have no trouble finding an aftermarket loader for it, although I recommend you stick with the 4' bucket. You'll also appreciate the front loader when it comes to counterbalancing those implements.
//greg//
/ Name this tractor
Taking the tractor out of 4 wheel for FEL work??? That's the first I've heard of this. Can you explain further???
/ Name this tractor #10
I try to leave mine out of 4wd when doing loader work, rather use the 4wd drive as needed. I've seen some guys feel they're invincible using 4wd and end up fixing things in the end. Not saying 4w can't be used but it should be used with some caution.
/ Name this tractor #11
The 4wd Jinma 200 Series (18-28hp) has (a) no center differential, and (b) a documented weak front drive unit. Hundreds - if not thousands - of them have gone in for repairs directly attributable to aggressive loader work with 4wd engaged. Jinma's done very little over the years to correct the issue. Accordingly, reputable dealers recommend 2wd for aggressive loader work. Hence - a 2wd Jinma - to me - is a better choice for loader work. That said - if anticipated loader work is light duty or infrequent - the 4wd 200 Series may otherwise work out just fine for you.
Not all Chinese CUTs have this problem, just Jinma (far as I know). And then only in their 200 Series. The Jinma 300 series and larger have a more robust front drive unit. Just something to keep in mind when selecting a Chinese tractor to meet your expectations.
//greg//
/ Name this tractor #12
News to me too, especially when the load causes the rear wheels to slip.. Then you have NO BRakes???I looked at the same little tractor when it was FARMPRO...2 cylinder , that it pops like a old johndeere when running. It is very light...The front tire almost bounced from the pave,ment when it was idleing..A small hop, of course it was brand new..FEL is hard on the light front axles of CUTS...Next thing up, broken parts..
/ Name this tractor #16
Greg, I know you did a bunch of work on your chinese tractor? What made you go to JohnDeere? Just asking? I read often about the problems on this forum?
/ Name this tractor #17
I actually had 4 Chinese tractors, the first two were JM254s. I originally bought one to replace a YM240 because the 2wd was not up to some of the terrain I needed to work. First JM254 had significant electrical problems, the dealer replaced it. Second JM254 developed major clutch problems. Dispute with the dealer resulted in the regional manager intervention. He was so embarrassed by the dealers actions, that he not only took back the 2nd Jimna - but he told me to pick out any Chinese tractor from any dealer that I wanted - and he'd buy it for me. That's how I got my KM454 (45hp KAMA). I liked that one so much, I jumped on a used TS354C (TaiShan 35hp) with loader. It's a little brother to the KAMA.
By 2010, I got old enough to draw on all those Social Security dollars I'd paid in over the years. The resultant monthly check was such that it would pay for a new tractor. So I traded both the KAMA and the TaiShan in on a John Deere 3720 cab with 4-in-1 loader. Got $10k trade-in, and John Deere is carrying the balance at 0%. Social Security check more than covers the payments. Couldn't hardly pass it up.
FYI, problem with the 4wd 200 Series w/loader usually happened when operator would slam into pile. That often takes weight off the rear tires, which in turn is transferred to the fronts. With no center differential, the larger mass of the spinning rear tires gets transferred through the drivetrain forward to the stationary front drive. Usually something in the front differential broke. Conversely, if conditions are such that the fronts spin faster than the rears, damage is usually in the front outboard drive units. The 200 Series front drive system is simply not robust enough to deal with the kind of aggressive loader activity that is considered normal for other 4wd tractors. Hence, the 2wd Jinma 200 series - to me - makes a better loader tractor.
//greg//
/ Name this tractor #18
I turned 62 in 2010, and decided to draw on all those Social Security dollars I'd paid in over the years. So I traded both the KAMA and the TaiShan in on a John Deere 3720 cab with 4-in-1 loader. It was eventually delivered as a 2011 model last March. Got $10k trade-in for the Chinese tractors, and John Deere is carrying the balance at 0% financing. Payments are coming out of my Social Security check. In the end, it was just a combination of circumstances that I couldn't pass up.
//greg//
2021 Scag Turf Tiger II 52in Zero Turn Commercial Mower (A64194)
2021 Scag Turf...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2017 Autocar Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A64556)
2017 Autocar...
2014 Nissan Sentra Sedan (A64557)
2014 Nissan Sentra...
