n00b HYD quick Connect question
   / n00b HYD quick Connect question
I think he has the true 3rd function valve, but regardless, your point seems valid to me, he should press both buttons each in turn with the key on to relieve pressure. Worth a try anyway.
James K0UA
I believe I have a WR Long 3rd function valve. Cost me $800.
There is an electric valve assembly under the tractor near the seat mounts I think.
David
   / n00b HYD quick Connect question #12
J_J,
I changed the back side to 90 degree to prevent the breakage I had.
I am sorry the picture is cropped, but I believe they are already 45 degree on the QD side...
Not sure I understand how that reduces pressure though...
David
A lot of fitting will reduce pressure somewhat. Some more than others. Far instance, a 90 degree fitting will reduce the pressure, but two 45 degree fitting will reduce the pressure even less. Just a couple of fittings will not make a big difference.
125cc EGL Motor Dirtbike (A57453)
125cc EGL Motor...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2011 Mercedes-Benz E-Class Sedan (A56859)
2011 Mercedes-Benz...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
Zero Turn Mower (A59231)
Zero Turn Mower...
