My Stupid Problem
Status
Not open for further replies.
/ My Stupid Problem #24
I believe its attached to the drawbar Mr.Know-it-all:laughing::laughing::laughing:
/ My Stupid Problem #26
Good grief !! I wish you good luck getting that out intact !!
/ My Stupid Problem #27
You could also use the front loader and lift the front of the mower a couple feet and drag her out. Pulling in reverse.
Main thing is to not get hurt. No shame in calling for help
/ My Stupid Problem #28
If you price a field to bush hog without walking it first your due whatever happens to you , Hopefully after the first time you learn what not to do !!
By god your the most positive person on this website,you come by your name honestly(GRUMPY OLD MAN).To the orginal poster hope it works out well for you.Do you know anyone with a 3 ton manual chain hoist?If so if there is a big tree close hook up a log chain and hoist away.coobie
/ My Stupid Problem #29
the problem isn't pulling the mower out. Grumpy's tractor may even do it. The problem is getting it out without caving in the hole under
the tractor. I don't know if Dt's loader will lift it but if he tries he will put a lot of weight above the hole that's under the tractor. I realize
that the tractor is above the hole now. I would want something big enough to pull it out if the hole UNDER the tractor starts to give way'
Pan
/ My Stupid Problem #30
I think I would consider renting a small all terrain crane to hook up to it.......
/ My Stupid Problem #31
Pan
your right my 855 might pull it out or my 941 loader or my 580 backhoe , Really guys this thing is not that stuck by what I can see from the pictures ,Would it not be easy enough to drop the mower and just use the loader to pull it up and out ,You can see theres no sense trying to jack it up from the rear and if the tractor just can't muscle it out ,Other than using some skills to use the loader and chains in the position it sits in the easiest way would be to drop it and use the loader .if need be add some ballast
/ My Stupid Problem #32
Grumpy, either you seem to be forgetting about the hole under the tractor or do not think it is much of an issue
Personally, I feel it is a HAIL of an issue
/ My Stupid Problem #33
i'm looking at the pictures and the tractor is 3 feet from the hole , The outside tires of the mower look as tho they are stuck 2 feet outside of the hole and if it were me I'd drop the clutch and ride it out !
/ My Stupid Problem #34
"What we have is a sink hole 12 or so feet deep with an opening about 5'x8' and nearly vertical sides. It opens up on one side and goes much deeper UNDER the tractor."
If he could unhook it might just go to the bottom.
/ My Stupid Problem #35
Ok so wouldn't the best idea be to risk the mower and save the tractor by unhitching it and pulling far foward then take a 20 foot chain and just drag the mower away from the hole ??? Short of getting a helicopter and lifting straight up thats pretty much your option ??? Isn't it ???
/ My Stupid Problem #38
I have no experience in this type of extraction, so I will only wish you a safe recovery.
Good luck, be safe.
/ My Stupid Problem #39
Good luck, be safe.
/ My Stupid Problem #40
If the tractor is keeping the mower from going in you may not be able to unhook it.
If you unhook it you could cause the hole to cave in with you between the tractor and mower
with the tractor headed backwards into the hole.
Pan
Status
40' 6 Door Shipping Container (A68183)
40' 6 Door...
PORTA POTTY (A68842)
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
