My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
You can expect up to 3% stretch in the length of your belt
- That's good to know. The spacing between the track bars are such that if it gets too long for my takeup, I can cut a piece off each belt and resplice it - NBD.
Over the last couple of days, I fabbed up and installed the cargo rack today.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #323
You need to keep on this project. I've been kicked out of the school shop (contra virus thing) so your project is all I got going.... :laughing:
Hi Arly - with the weather starting to break, I have had to work on some yard-related items which of course, takes away from my fun time working on Snowzer. I do have the inner steel door frames all welded up and plan to work on the outer aluminum frames shortly. I have the steering hydraulics bled and hopefully they will work OK without adding boosters. The service brake system is another issue. The master cylinder I bought was too small and would not move enough fluid to grasp the rotors sufficiently. I bought a larger one that was originally designed for use on a mid-60's ford sedan. I'll post photos when I get it assembled.
Working on door frames. You can never have enough clamps... :)
The new service brake master cylinder and operating linkage has now been assembled and installed. There is now about 1/4" of pedal travel before the calipers start grabbing the rotors. I wonder if the 1-1/4" piston in the master cylinder is too big now. Time will tell once I get to driving it around the yard hopefully next week if the weather starts to behave. I plan to continue working on the doors over the next few rainy days.
Yes - each door is made like a sandwich with inner and outer frames made from 1/4" x 2" stock - steel on the inside and aluminum on the outside. Between the two frames will be a piece of aluminum sheet placed below the lock mechanism and a piece of Lexan above it. The frames will be screwed together with SST flat head screws tapped into the steel frame.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #330
Do you like the 1/4" travel? Changing the geometry by moving pedal linkage toward or away from the pivot will remove or add distance but I'm sure you already know that. Just a random thought. :)
Looking forward to seeing it move around.
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A59575)
2016 FORD F-550...
THREE POINT ATTACHMENT (A58216)
THREE POINT...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
