My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #201
I wonder if vinyl fabric would reflect much noise or deaden sound somewhat if installed on the inside cab walls. It is rather inexpensive and would be easy to install. I don't expect much engine noise in the cab - the engine is located in a separate compartment at the rear. I would expect the most noise to come from the diff under the cab floor. There will be a rubbery floor mat covering the floor plates (12 ga - .108" sheet).
Instead of your 12 gauge floor rubber, consider a rubber product that is much heavier as the additional mass greatly helps sound deadening. TSC rubber mats for cows to lie on come to mind.
When insulating ductwork in critical areas for minimal sound intrusion, a heavy insulation was used that had a lead layer as part of the assembly. Of course I am now showing my age...
Using the same rubber product between the engine compartment and cab would also improve the isolation. Zero turn mowers by Toro have as an optional extra, a heavy rubber pad to lie where your feet go to block the sounds from the mower deck.
Cannot wait to see your project in motion!!
DaveM7040
I've been working on the cab and cargo frame the last few weeks by adding outer sheet metal skins and insulation. I hope to get things primed and painted once the crappy weather here in upstate NY improves. I also started work on the driveshaft which will utilize an Echo axle and its CV joints with a piece of 1-1/2" sch 80 pipe used to connect them all welded together. If that doesn't work, I'll plan to re-purpose a Rav4 driveshaft and its U-joints.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #203
You could put a product called Dynomat on over your insulation, it;s for sound deadening.
I haven't read the entire thread yet (You can bet I will) but what are you using for tracks?
Keep the updates coming please. I had always wanted to build a tracked vehicle exactly like you are doing except using generic junk yard parts. After a heart attack I have since given up on that idea.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #204
-> actually, I may at some point, install a two-speed transfer case and reverse it. There's plenty of room in the tub frame to do that. Anyone got one laying around they want to get rid of cheap? ;)
Look for a NP231 transfer case, they can be found in any Jeep (YJ, TJ, Cherokee, Chevy trucks etc) cheap, plentiful and lightweight.
Even though yard work, the honey-do list and other tasks have eaten up a bunch of my prior free time, I have been able to get some more work done on the outer cab skins and front/rear driving lights. I also finalized a logo design and plan to have some decals made up.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #206
Cool progress, glad to see you moving along! I like the logo too.
I've been making some progress on the cab. Today I cut up some .090 sheet for the roof using the plasma cutter and tacked it in place. Earlier this week I added the cab underside panels and final painted them. There's a chance I'll finish painting the cab exterior in International Harvester Flame Red later this week. I also recently received the windshield made from 1/4" laminated safety glass and test fitted it.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #208
Looking forward to the first test run video!
Progress on the cab continues. I painted the first coat on it today. I hope to add a clear coat tomorrow.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #210
Progressing nicely! We finally got some decent weather to work outdoors in.
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
197390 (A50459)
197390 (A50459)
