My NX6010
   / My NX6010
Please correct me if I'm wrong, but I've owned many (17) diesel pickups. Diesel's should never be left idling in sub zero temps. Your RPM's should be bumped up 1250-1500 to keep cylinder temps high enough to allow full fuel burn. If left sitting at idle, you're going to run into cylinder wash. I've always bumped my idle up 12-1300 after 1-2 min at idle. I do this with all of my pickups and tractors and haven't had a problem to date. By doing this you will also have faster warm up times.
Diesel trucks have a cold idle stepper motor that automatically increases the idle rpm, or steps the idle up if you tab the gas after a cold start.
   / My NX6010
Wow, hadn't even thought about the tier 4 complications ....
Nobody talking in this thread has thought about tier 4 except the Ford tech who mentioned the new trucks have an inline electric heater.
At any-rate, I will eventually get things squared away.
Today I used 3M spray adhesive to glue a pad onto my chainsaw carrier I'm making.
I also got around to addressing a leak on the female 3rd function quick disconnect. Another previous day I had replaced the male, but that didn't fix the leak, so today I pulled the plumbing out so i could get at things.
And while doing that, I noticed one of the loader's lines was working against the lower windscreen and so I made a little guard for it from a leftover hydraulic sock.
I also moved the damaged QD in the back from the middle of the stack to the top of the stack for easier access when I can locate a replacement.
Sangki mades this rear quick disconnect, and I need to find a vender because my dealer informed me that through them, the disconnects are silly expensive. I've had lno luck searching.
In other news, I started working on beefing up what will become the mount for my new chainsaw holder.
   / My NX6010 #324
For what it is worth... IMO you would be better off leaving that tractor run at 1300 to 1400RPM to keep heat in the exhaust system and the egts hot if your going to be off it for a few minutes vs shutting it on and off all day, then if it senses it needs to do a burn it can.
I drive a 2014 Peterbuilt at work with a 525 horse Cummins. It has a dpf, egr cooler ,and takes DEF also...The word from the factory...don't let it idle for more than 5 minutes..bump the rpm up if sitting running longer than that...I read in the owners book that to initiate a automatic burn while driving, the computer has to sense enough heat in the exhaust system before it will initiate the regen cycle, as of right now, it does a burn about once a week...I put 300 to 400 miles a day on it.
Word from the mechanics..drive it like you stole it..lol
The harder your run them, the less problems you have with the emmisions system.
   / My NX6010 #325
Thank you for your thoughts. I mess up nomenclature all of the time. And names. I try not to, my bad. Bad enough that I do it when talking but my auto-spell changes words on me all the time. Gets really bad when it is trying to auto correct an option chain. At any-rate, I cannot be revving up an engine at 10 degrees or less to warm it up. The tractor will be stored in my sister's unheated pole barn and tasked with whatever they want. For that reason I'm also considering a circulation engine heater such as Zerostart's 8000 series. According to their literature, a 750 watt heater should take a stone cold engine to 120 degrees in about half and hour of being plugged in.
A 330-5036 in this
http://www.phillipsandtemro.com/userfiles//Industrial Tank Circulation Engine Heater Sellsheet.pdf
Or a 3308001 in the 8000 series for a 750 watt circulation heater.
http://www.phillipsandtemro.com/userfiles//Series 8000 Tank Circulation Heater.pdf
If anybody wants to go off the deep end and find all kinds of products that keep fluids like brake lines from freezing and fuel lines from freezing, to external cab heaters, here you go.
Phillips & Temro - Literature
Edit: After hunting around, I decided to go with the industrial 1000W application. The least expensive source I found was here: ZeroStart - 330-5048 - 1000W Industrial Circulation Heater
With a circulation heater all you are going to do is warm the coolant. You are still going to have cold engine oil and hydraulic oil so you are not going to be able to jump in your tractor and go to work. It is still going to need to warm up.
   / My NX6010
To mount the chainsaw holder I made, I needed to beef up the rear window wash reservoir cover with a pair of gussets so the cover could support the additional weight of a saw and the saw mount.
Bottom
Even though the window wash reservoir is flat, begging to have something bolted up to it, there are all kinds of little clearance issues, not the least of which is the rear window opening. For that reason I used standoffs to clear the rear brake light.
Anyway, the result should give the operator years of service.
YRC just called and it sounds like my new Everything Attachment's box grader is in. It also sounds like the circulating water heater will be delivered this afternoon, and it looks like it is time for me to get my dock in, as this is what is happening in northern Minnesota.
   / My NX6010 #327
I really like your chainsaw holder a lot! And please keep that white stuff up there for as long as possible! :)
   / My NX6010 #328
I've purchased a JVC KDX310BT radio from Amazon At any-rate, I want a radio to work with my iPhone over bluetooth so I can stream my toe-tappers and be able to tune in my two crazy local Indian variety stations and the oldies station broadcasting out of Park Rapids, MN (89.9 KKWE, 90.5 and 97.5FM respectively if you're in Hubbard or Cass Counties).
I don't know how good the stock speakers are and so I'll try them out first before making a judgment about them.
Eric, did you just splice the factory wires for this or were you able to find a wiring harness?
   / My NX6010 #329
[snip]
[snip]
Clever, Eric. You're right about the rear windshield washer reservoir cover begging to have something bolted to it. I've been thinking about what to use if for for awhile, and your idea is a good one. :thumbsup: I like it better than mounting the holder on one of the FEL lift arms, which is another way I've seen it done.
   / My NX6010
While I did post the wiring diagram for those who want to swap out to a different radio in their NX cab tractors, I never got around to installing the new radio because I have not found the right face plate with two screws on opposite sides, or failing that I need to make yet another bracket that holds the radio and accepts the screws in the locations of wherever they go in the replacement radio bezel.
However, it is now too cold outside for me to want to fab a bracket outside. As it is, it is getting too cold for me to want to work in my unheated garage.
Next year, as I have time. But next spring's high nail will be to list and sell my city house. If I get nothing else done next year, I need to get that done.
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
Deere 35G (A53317)
Deere 35G (A53317)
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
