My NX6010
   / My NX6010 #901
There is a difference with stall-guard on or off, but I never geeked out enough to find out how it works. Since this is an electrically controlled HST, without checking, I presumed that when the engine started to stall, the ECU backed off the user requested load from the forward and rearward signal sent to the HST computer even if the user continued to mash the go pedal all the way down, but I don't really know.
Kioti may have a different way of doing things.
When stall guard kicks in on my tractor the hydro sounds different.
   / My NX6010
My tractor goes VVVVVVVVVvvvvvvvvrrrr stop.
<stick it in neutral, press the brake down, turn the key>
VVVVVVVVVVVVVVVVVV
:laughing:
   / My NX6010 #903
It's interesting how many different ideas on how hydraulic systems work there are.
EricTheOracle said:
At low volume, a given ram will not move under a given load because the relief opens before enough volume of fluid can develop to overcome the load.
Not true at all. Volume (GPM = flow) does not matter. The lifting capability of the ram, and the functionality of the relief are governed solely by the pressure. But the lower the flow, the slower it will be. To have the relief open, the set pressure of the relief has to be met... if it's capable of getting there, it's capable of moving the load.
This is one of the most basic concepts of physics.
A .05GPM source of 3000PSI will lift the same load with the same cylinder as a 30GPM source at 3000PSI. It will just take MUCH longer. This is pretty simple, and compares via the law of the conservation of energy of RPM vs torque, volts vs amps, etc.
A certain input RPM does not guarantee the pump will be able to build that pressure though, depending on the pump design... but for our purposes...
EricTheOracle said:
That said, 94BULLITT, where did the 14.9hp spec come from? If true, I should have maximum lift at idle, but I don't. I do not doubt your sincerity, but that number cannot be right. If my tractor only needs 14.9 horsepower to generate maximum pressure and maximum flow in an open center system under maximum load is really true, then 25hp subcompact tractors should have monster lift specs, and I and everybody else have been taken.
Pump GPM is proportionate to input RPM, it won't produce the rated flow at a lower RPM than designed. At X GPM and Y PSI, you can find a specific horsepower number required for the input to maintain that output.
A 1/2HP 12vdc hydraulic pump is capable of lifting the same thing as your tractor. It will just take much longer.
Physics come into play. A loader on your example 25hp tractor will flip the tractor over before it lifts 4000 lbs, so it is designed to lift what it can lift efficiently, and not for the maximum lift.
With the engine revved up, the loader maxed, the engine stays revving and the hydro goes to relief. The HST, pump can stall the engine when under a load and combos of the HST pump and load on the loader can and does stall the engine even with anti-stall switched on (a feature, I've never puzzled out what it tries to do).
The HST is a variable displacement pump type, there is not a relief that regulates pressure like the pump for the loader/3 point/remotes/etc... at least not in the circuit with the motor/pump, and at least not before it consumes all available power. That's why it can stall the engine. Don't think of it as a simple open center hydraulic system like used for the loader, where you could direct 100% of the flow through a hydraulic motor, lock it up and have the pressure hit the relief and everything goes on as planned Think of it more as a closed center pump connected directly to a motor - the input to the pump is directly the output of the motor and vice versa. Lock up the motor and the pump will stop (unless something gives first!)
The working HP of the system does not mean it cannot produce a load on the engine greater than that and stall the engine. The HST can and will take up 100% of the power the engine puts out.
The control for a Kubota or Kioti HST is the same - the swash plates, whether that is done mechanically or electronically to accomplish the goal and features, it doesn't much matter.
   / My NX6010 #904
The stall guard on Kubotas opens the swash plates to keep the engine from stalling. The tractor accelerates faster with it on, pulls hills better, and it kicks in under a heavy load like while grading or digging wit the loader, improving performance. I was going up a steep hill in High range and turned stall guard off and the tractor dropped 2MPH instantly.
That's not simply the swash plates then. Your foot on the pedal directly (or indirectly if electronic) controls them, "opening" them would be equivalent to you letting off the pedal.
   / My NX6010
Please be forgiving of me for not presenting things clearly. Fluid moving has lower pressure than static fluid. We know that our arms can slowly pump a 40 ton bottle jack. The issue then is higher horsepower allows more fluid to flow thereby allowing the operator to work faster.
I can certainly understand how you understood that I was speaking about relief on the HST side from my remark, "The basic take-away is that higher flowing fluid has lower pressure than slower moving pressure and so more work can be done before going to relief." Although I was not clear the relief I'm speaking about is on the hydro side, not on the HST side. The context here is the video I made and posted where the wheels are still spinning and the loader has sent the hydro system to relief.
Thank you for your remarks as they serve to clarify since I did not make myself clear.
   / My NX6010 #906
Eric, I made a quick video so you can see how a compact with 44hp works:)
   / My NX6010 #907
   / My NX6010
I had to be careful about lifting the rear end off of the ground when I drove into the material in the video I made. And then, if I didn't throttle up and I left the throttle matching feature on (which I always do), the tractor would bog down or conk out when I drove into my pile of sphagnum top soil I scraped off of my clearing. As you can see, the material doesn't even want to fall out of my dump trailer, let alone allow itself to get scooped up.
My tractor also bogs down while pushing a blade unless I throttle it up too.
Maybe Kapper can share his thoughts on a comparison between his 66hp John Deere 4720 and his NX6010 since he uses both?
   / My NX6010
I did an ad hoc 200 hour review of my NX6010.
2021 Ford F-250 (A55973)
2021 Ford F-250...
LOT: (8) Chain Binders (A59076)
LOT: (8) Chain...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
