My NX6010
   / My NX6010
Nice job on the video Eric.
I've noticed in a couple of Kappers videos and this last video that you made the NX6010s engine seems to bog easily. I wonder what is up with that?
What is going on is that I'm auguring into a pile of dirt, and while still moving forward, hitting relief pressure on the loader and rather than backing off all the way, I'm working the forward and rearward pedals until the loader finds whatever it can lift while moving. While doing this the engine bogs and so I've got to back off just enough to allow the engine to spin back up, and then back into it!
However, if I'm trying to pick up a log that is too heavy but not moving forward or backward, so long as the engine is throttled up, the engine will not bog down. Instead it'll just go to relief.
The same thing happens with skid loaders too since they (or the ones I've seen) use open center pumps which can overwhelm the engine if they are loaded both by the HST and the hydraulic pump.
   / My NX6010 #882
It takes 14.9HP to operate your loader at max pressure and GPM, you are left with 45hp to "move" the tractor. 45hp should be more than enough hp to propel a tractor that is under 7,000lbs especially without a ballast on the 3PH because it will spin easier without a ballast.
   / My NX6010 #883
   / My NX6010 #884
tractor is not 7000 lbs when the loader is at the max lifting force/relief valve and in 4 wheel drive.
   / My NX6010
And the additional 1250 pounds of Rim Guard in all four tires as well as the 150 pounds go CAT 2 Quick Hitch.
Figure the loader is 1100ish pounds (wild guess since I've never seen a weight spec on the KL6010 loader), the bucket its at least 300 pounds, the tractor 4600ish pounds, 1250 pounds of ballast, 150 pounds for the quick hitch, and we're at 7100 pounds. Now figure the loader is attempting to pick up 3000 pounds because we're both driving in and lifting at the same time (official loader rating is 2700 pounds).
That said, 94BULLITT, where did the 14.9hp spec come from? If true, I should have maximum lift at idle, but I don't. I do not doubt your sincerity, but that number cannot be right. If my tractor only needs 14.9 horsepower to generate maximum pressure and maximum flow in an open center system under maximum load is really true, then 25hp subcompact tractors should have monster lift specs, and I and everybody else have been taken. Consider that if 14.9 hp is true, then Island's outrageous argument is right: his little tractor can do everything the bigger NX series can do and do it just as fast as the larger, faster NX series and we're all fools for buying bigger tractors!
   / My NX6010 #886
I would imagine the 15 hp figure is about right. My DK40 has exactly the same lift capacity as the NX6010. 2760lbs. There is a big difference at the PTO end but not much if anything with the loader.
   / My NX6010
Sigh. Okay the only thing the engine is spinning is a hydraulic pump. The pump is positive displacement, meaning that what goes in must come out or it explodes or stalls.
Ask yourself, if the engine is running faster or slower, if there a difference in flow?
Answer: yes, there is a difference in flow.
Ask yourself, is the pump able to go to relief pressure at idle?
Answer: yes. It is possible to nab something with the loader at idle and go to relief.
Ask yourself, why then is more lifting power available at high engine speed?
Answer: the volume of flow. The speed of flow allows more work to be done even as the relief is varying its opening and blowing off excess pressure. This is because pressure on fluid is the same everywhere when the fluid isn't moving but this isn't true when the fluid is moving. At low volume, a given ram will not move under a given load because the relief opens before enough volume of fluid can develop to overcome the load. At higher volume, enough fluid is moving to fill the ram to keep it moving even as excessive pressure is flowing past the relief valve. Thus more work is work is done with higher volume and higher engine power allows the work to be done faster on a given ram size than a lower engine speed or lower engine power. For this reason the 45-60hp NX series have the same spec loader lift spec ratings.
I tried to find an animation to show how this works as it isn't super intuitive. What I found is a closed center system animation. Fine, just presume, a valve that flows pump output back to tank when not working the valve rather than through the relief. what I liked about this animation is that it attempts to show pressure under different loads while the ram is moving and the speed at which work can be done. The animation doesn't get into fluid dynamics and Bernoulli's Equation, which is what I really wanted to try and show.
The basic take-away is that higher flowing fluid has lower pressure than slower moving pressure and so more work can be done before going to relief.
   / My NX6010
Here is an explanation of Bernoulli's Equation.
   / My NX6010 #889
Fine. I think Bernoulli is a great guy and I like drinking Heinekens with him when I visit Amsterdam but perhaps Blaise Pascal is more relevant here. For a given pressure created by the hydraulic pump and limited by the pressure relief valve, the output power acting on an identical cylinder would be the same. I don't see where having more power creating that same pressure makes much difference if any in this closed system. I believe the pumps on the two tractors are pretty similar in capacity (NX about 6-7% greater gallons/min than DK: 17.9 vs 16.8gpm). But the key point is that the pressure relief valve means that the extra power available on the NX cannot add significantly to loader function either in lift capacity or cycle speed under load. Without load both loaders (KL401 and KL6010) are rated at PTO RPM to raise the bucket in exactly the same time of 4.5 seconds. There might be a second or less advantage in raising a near capacity load to travel height. Big deal. They still raise exactly the same max load which is obvious given they have the same loader geometry, and cylinder size.
From a purely practical point of view, it's not like the DK40 requires ten minutes to lift a large stump or rock or chunk of concrete. I don't lift those things to full height but when I lift them running at 1800=2000rpm they come off the ground pretty much the same speed as when I am lifting an empty grapple at idle. Works for me. Certainly it doesn't take more than a few seconds more to reach carrying/transport height. What's the reason I would need more power to run my loader???
As noted earlier, if you are running something power hungry on the PTO then the extra horses mean something as they would towing a heavy trailer or big plow but as far as the loader is concerned a 40hp Kioti ends in a dead heat with a 60hp Kioti.
By the way, you were wondering what your loader weighs. Given that the KL401 weighs 1284lbs, I cannot imagine the KL6010 weighs much more.
   / My NX6010 #890
I looked up the specs for your loader, the GPM (10GPM) and pressure (2556psi). http://www.kioti.com/products/attachments/front-end-loaders/kl6010/
Here is the formula. 10x2556=25,560/1714=14.91HP I have very close to max lift at idle with the L4240. I don't have a way to compare and see how much it will lift at idle and full throttle but it not much of a difference. Horsepower has nothing to do with lift specs on a tractor. The size of the cylinders on the loader and the relief valve setting on a loader are what it important. I could take CS2410 and put larger cylinders on the loader to make it lift more. The loader cylce times would be slower though. As far as the debate on HP, if Island tractor is pulling a box blade with his DK40 and it fills up and the tractor looses traction what good would more power be? Where you will really notice more power is driving the tractor down the road. The tractor with more power will pull the hills better. More power will allow you to run larger PTO driven implements.
Here is a video where I noticed bogging, even at 1:20 backing up.
I agree:)
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
2020 Peterbilt 367 (A55973)
2020 Peterbilt 367...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2008 UTILITY DRY VAN TRAILER 53X102 (A57880)
2008 UTILITY DRY...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
