My NX6010
/ My NX6010 #1,321
Not a solution, though it might be of help (for you or others), but my NX can be a bear to shift into "M". I have found that having the engine's RPMs around 1,500-1,600 helps quite a bit: higher or lower and it's harder to get to shift. I've also resorted to turning the front wheels/steering around, which tends to, I'm thinking, alter the fluid flow and pressures. Your situation is FAR more troubling and my note here is unlikely to pacify you, but perhaps it might allow you to get it operate a bit until you get a final resolution.
NOTE: I'm approaching 800 hrs on my (2016) NX. All in all I can say that I am totally fine with this purchase. It took me a while before I could say that. I've had issues and, thankfully, the bigger ones (leaking rear diff case) were taken care of by the dealer under warranty*.
* I'll point out that it's better to work a new tractor hard than to baby it along (like a garage queen) because otherwise you may not force a weak item to give way under warranty.
/ My NX6010 #1,322
It's probably fair, I'm just tight. That is almost 3 days pay just to transport it. No telling what the repair might cost?
Small comfort, but I agree with Eric that $150 for pickup and $150 for delivery after service is not bad, especially right now. Please keep us posted on what the dealer's service dept finds. Good luck!
/ My NX6010 #1,323
Hi Diesel, thank you for the comments.
Although this is my first tractor, it has 1300 hrs. on it. The person I purchased from said he used it for brush hogging and splitting wood, so it seems like he worked it fairly good.
Aside from the range shifter being out of adjustment/sync with the dashboard light and transmission, I too have a hard time getting it into M from the Neutral between L and M. I've never been above M, so I don't know about shifting from the N above M to M. I'm not sure why it even has two Neutrals? I'll try to get the RPM's up next time wave see what happens.
/ My NX6010 #1,324
$150 for each way isn't too bad considering chaining down time.
Hi Eric,
I just watched your video on YouTube where you had a problem with you range shift lever popping out of range into neutral. That video showed where the shifter linkage is located. I will take a look at that to see what I can see. Is there anything I should be looking for that might indicate a problem? Do you know where the shifter safety switch is located? You mentioned that potentially being the problem. I'm not too good at reading the schematic.
Did you ever get your shifter problem resolved?
/ My NX6010 #1,325
Hi Threepoint,
I'm going to look at the linkage now that I know where to look (per Eric's YouTube video). If I don't see anything messed up, I'll probably bite the $$ bullet and have the Kioti dealer come pick it up and fix it.
I'll give an update as things develop.
I really appreciate ALL of you guys trying to help me!!
/ My NX6010 #1,326
Hi Threepoint,
Hey Eric, you ain't going to believe this...
I watched your YouTube video that showed you pointing out where the shifter linkage is located. I went out to look at my tractor and noticed there was a bunch of debris, (small sticks and such) lodged in the linkage. I reached in and started pulling stuff out but couldn't reach all the way so I bit a broom handle and getting pushed what I could out. I then got the air compressor out and blew the packed dirt loose and out.
As I was getting in the tractor I looked between the rear tire and cab and noticed I could see the linkage. I reached up and grabbed the range shifter and moved the shifter one range at a time threw the whole range. Icould see the kinkage moving as I did. The shifter moved so easily and securely at each range.
I got in and put the shifter in N (per the shifter label) the dash said N too. I went through all ranges and the dash matched each time. Then the moment of Truth... I put the shifter in N and tried see if it would start.
IT DID!!!
I drove it and checked each range. They all worked and synced with the dash.
I WOULD LIKE TO SAY A BIG THANK YOU TO YOU ERIC !!
You saved me a lot of aggravation and money !!
/ My NX6010
IT DID!!!
LOL. That's an older video but I'm glad I could help! You know the deal. Thumbs up, write a comment on YouTube so the Algo that is run by the AI god notices my channel.
Meanwhile, I cannot believe my "How a mechanic washes his dog," video hasn't gone viral. lol
/ My NX6010 #1,328
I Liked and Saved the video. What grapple is that you have. I'm looking for one. Also, I have a drainage ditch that is about 300 get long and 3-4 feet wide that is overgrown. I want to cut down the vegetation and maintain it that way. I'm afraid to try and straddle it with the tractor and brush hog. What implement would you recommend?
Thanks again for your help!
/ My NX6010
The drainage ditch doesn't look deep or steep. Drive in there with your rotary cutter or use a regular law mower. The Grapply I have is an Everything Attachments 72" wide version 1.0 double lid wicked roots grapple. On my properties it is a my go-to attachment and is primarily used to pick up windfalls and once in a while to clean up improved areas. I'd purchase it again.
/ My NX6010 #1,330
Arnold, congratulations on solving the problem with the shifter! Eric's the man! He's helped many folks on this board in the past. Including me.
I think you are really going to enjoy the NX4510HST/cab, especially with that pesky issue gone. I have the same tractor, 2014 model.
I also have an Everything Attachments Wicked Root Grapple like Eric's, but in the 60" width. I initially thought I wanted a 72", since that is the width of the bucket it replaces, but decided to go with 60" after discussing it with Travis at EA. I'd buy it again with no hesitation.
/ My NX6010 #1,331
Hi Threepoint,
I'm ecstatic the shifter it's working right and didn't cost me anything!
I'm thinking my first implement purchase will be a root grapple. What made you decide on the 60" rather than the 72" like your bucket?
/ My NX6010 #1,332
Hi Eric,
I'm looking at grapples myself. I think it would be a good first implement purchase. Your have a 72" and Threepoint went with the 60". What should I be considering when making my choice?
/ My NX6010
Hi Eric,
Probably easier for me to talk about this on the phone and provide a survey to bring you up to speed.
/ My NX6010 #1,334
That sounds good Eric. It will be Thursday before I will have an opportunity to talk. Is Thursday evening good for you?
/ My NX6010 #1,335
Hi Threepoint,
I also considered the 66" width before going with the 60." All three widths would be fine for the size tractor you have, but for me the 60" aids maneuverability without really giving anything up. I believe the dimensions of the double lids are the same for all three widths. So you lose nothing in terms of downward clamping ability. Sizing a grapple is different than sizing a bucket, where an extra 12" of width can mean a big difference in carrying capacity of loose material. In my woods, and in other areas where I work, I can poke the grapple into narrow spots between trees, stumps, bushes and other plantings I don't want to disturb, etc.
The narrower width also concentrates both the penetration force and the lifting force a bit more when digging out stuff. This is just my experience. It's worth a chat with Travis at EA about the best width for you based on your particular situation.
One final thought. A few years after getting the 60" grapple, I added another tractor, a 2018 CK3510SE HST. As it turns out, the 60" grapple is a perfect size for that tractor, where a 72" would be too large. And now that's where mine pretty much stays! So if you think a second tractor may be in your future, consider sizing with that in mine as well. :)
/ My NX6010 #1,337
Good morning Eric, I'm helping a friend move some furniture after work. Has the food overtaken you by 7:30 EST?
/ My NX6010 #1,338
I have the same problem with my 2023 NX610. The CAL light comes on, and the tractor will not move. Sometimes, flipping the call button fixes it. The last time I was at the edge of my lake, the engine stopped. After trying to start and flipping the CAL button, it finally started. I have been to two dealers and still have the problem. Does anyone have any ideas on how to fix it?
/ My NX6010 #1,339
If you look around you can find the procedure to re-calibrate. My NX had started to toss itself into fits more frequently and after going through the re-calibration steps life was all good.
/ My NX6010
Loose connection on the left side of the transmission. Pull the only electrical connector off of the transmission on the left side and plug it back in again.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
John Deere 5525 (A60462)
John Deere 5525...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
