My NX6010
/ My NX6010 #821
To be honest, after spending $$$ to put a rear remote valve stack kit on my Kubota and add a hydraulic top link, I'd be pretty annoyed if it leaked so bad I needed a check valve to hold the cylinder in place. That would kill one huge benefit I was shooting for with a float/detent valve in the stack. To the point where I might not have done it in the first place.
Some leakage in a top link would likely not be that noticeable or much of an issue.
Any leakage, Even a Small amount from a cylinder or the valve on a side link is very noticeable and a huge PITA.
/ My NX6010 #822
I may add a tilt cylinder to mine, not sure yet, but I too thought about leaving the adjustable one on, why not just install the hydro one on the left where the factory solid link is?
Most people put the hydraulic side link on the left and the manual on the right.
/ My NX6010 #823
Did you mean to say it that way? I've never heard of anyone doing that. I've always heard hydraulic where the adjustable one was, replace fixed with adjustable. I thought most people expected to adjust the right and only played with the left by necessity.
<tongue in cheek>Since that's the way I do it, then everyone else does too. Right?</tongue in cheek>
/ My NX6010 #824
I said it backwards. Put the manual on the left and hydraulic on the right.
/ My NX6010 #826
Do you guys actually use two adjustable side links? What is the advantage? Seems to me that any single adjustable side link can tilt the implement in either direction so why have two?
/ My NX6010 #827
You can get for tilt with 2 adjustable side links. With something like a box blade it can be handy.
/ My NX6010 #828
I presume you meant to type "more tilt". Is that used for digging ditches? Can't imagine a driveway that needs more of a crown than provided with a single adjustable side link.
/ My NX6010 #829
Yes, more tilt. It can be used for ditches, banks or whatever you need.
/ My NX6010 #830
Why not just go with 2 hydraulic side links:D
/ My NX6010 #831
Set the bar high.
What about a fully independent suspension with hydraulics on all 4 corners? A low rider tractor, if you will?
/ My NX6010 #832
The ONLY reason I do it is... because it's there.
I bought top'n'tilt after I bought my tractor. So, after removing the adjustable side link and replacing it with the hydraulic, why NOT put the adjustable on the other side?
I never expect to use it but it felt like a waste not to install it.
/ My NX6010
I started clearing off the lakeshore at the end of my point.
Mossy oak.
Different angle.
Nice, hard sand bottom.
As soon as my tractor hit the beach, a neighbor boated over to introduce himself mostly trying to figure out what I planned to do with the property.
After eight hours of picking up deadfalls, and yanking out rootballs, I had a result.
/ My NX6010 #834
I find that having the ability to float the side link, as well as the top link, is one of the major advantages of having them. I can see a big disadvantage to the check valve style cylinders, to the point where if I bought a tractor that had them, I'd purchase replacements.
However, the type of work I do with my tractor lends itself to that style better, whereas I'm sure the check valve style cylinders work for others, so use whatever works best in your situation :thumbsup:.
For any of you who haven't seen what two hydraulic side links are like, you can check this thread. I can see why having two cylinders could be advantageous in some situations.
http://www.tractorbynet.com/forums/owning-operating/116316-various-boxblade-uses.html (Note: He also uses check valve style cylinders, and gets along just fine without the float, all personal preference)
Awesome pics Eric! That lake shore is really looking nice! Good spot for a fire pit! That tractor looks is certainly earning it's keep around your place.
/ My NX6010
I popped in to mow the lawn.
And upload some videos. Here is the first one.
/ My NX6010 #836
Comments on video:
1) You have that nice heavy boxblade hanging off the back which is contributing to the bumpy ride but you are lifting only 200lbs or less of brush in each grapple load. Why not drop the box blade while collecting brush?
2) Or, use the box blade to smooth out that trail!
3) You are not compressing the brush. It would be much more efficient to crush several "bites" of brush into a single load before carrying it to the brush pile especially since that is more than a few yards away.
4) Why back up all the way instead of turning around? Seems to be enough of a clearing to turn.
/ My NX6010
Today I also swung by and paid for a new high-cube, double-door shipping container. I don't know if $5K is a good price or not, but a problem I had was finding people willing to transport the container to my site. The seller is charging $300 to drive nearly 200 miles. I figured this a good package price wise.
Manufactured in January this year but held up by the longshoreman strike.
/ My NX6010 #838
Any reason you bought a new one? Used are plentiful even in Michigan and cost less than half as much. Most folks get used ones for remote storage or even to convert into living space.
/ My NX6010 #839
/ My NX6010 #840
Thanks for the video, Eric. Looks like that suspension seat is working for you, although my lower back did still start to ache halfway through watching it. :laughing:
Even before I got to the end and saw the on-screen text, your camera work reminded me of the Discovery Channel show Survivorman. Survivorman Official Website - Les Stroud No cameraman, so in most everything he did, the guy had to hike, climb and wade stretches two or three times to get the approaching and following shots. :)
Island makes some points on the bumpy trail that occurred to me as well. I suspect you still have a lot of small stumps at this stage that make it tough to smooth it out even with that heavy new BB.
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
John Deere 694 (A64126)
John Deere 694...
VOLVO ROLLER (A65053)
John Deere 5055E (A64126)
John Deere 5055E...
