My Lumber and Plywood Cart
   / My Lumber and Plywood Cart #1
Xfaxman
Super Star Member
Guthrie, OK
Toolcat 5610 G - Bobcat V417 - TORO+Loader
The problem, all that stuff leaning against the wall:
Did an image search for ideas, found these:
The solution to the problem is my version of a storage cart starting with a saved 4' by 6' pallet that stall mats came on years ago. Added two 2x4s and casters:
   / My Lumber and Plywood Cart #2
Nicely done.
Ordered one 7 shelf unit for the vertical storage spaces:
And two of these for the horizontal slide in storage spaces:
The first one is expanded to fit and screwed down to the base:
Set the bottom half of the horizontal shelf in place:
Had to add short 2x4s to support the legs of the second shelf:
More progress:
Got the rest of the legs on last night:
And two sets of shelves on today:
Still have one set of shelves, need to decide if I want them at the top or in the bottom section.
   / My Lumber and Plywood Cart #8
I have the same problem and never knew of, or even thought of, a solution to it. I'm looking forward to see this all done and loaded up!!!
---------------------------- I'm looking forward to see this all done and loaded up!!!
Me too, but it is 74 degrees outside so the work on the cart will have to wait while I get outside stuff done.
Decided not to use the last set of shelves for now. I can install them later if needed. So it is finished for now. :thumbsup:
Added 1/2 inch EMT at a slant for the 4 foot wide sheets to lean against:
Moved the stuff from the wall onto the cart:
Still have a lot of room left on and in the shelves for lumber:
CASE 1850K LGP SERIES 3 CRALWER DOZER (A50458)
CASE 1850K LGP...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
Solid Tires (set of 4) (A49251)
Solid Tires (set...
2004 Komatsu WA75 Wheel Loader (A50397)
2004 Komatsu WA75...
Lyom-053 Unassembled Safety Basket Forklift Attachment (A46683)
Lyom-053...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A50397)
2018 Rock Solid...
