My Lumber and Plywood Cart
   / My Lumber and Plywood Cart #1
Xfaxman
Super Star Member
Guthrie, OK
Toolcat 5610 G - Bobcat V417 - TORO+Loader
The problem, all that stuff leaning against the wall:
Did an image search for ideas, found these:
The solution to the problem is my version of a storage cart starting with a saved 4' by 6' pallet that stall mats came on years ago. Added two 2x4s and casters:
   / My Lumber and Plywood Cart #2
Nicely done.
Ordered one 7 shelf unit for the vertical storage spaces:
And two of these for the horizontal slide in storage spaces:
The first one is expanded to fit and screwed down to the base:
Set the bottom half of the horizontal shelf in place:
Had to add short 2x4s to support the legs of the second shelf:
More progress:
Got the rest of the legs on last night:
And two sets of shelves on today:
Still have one set of shelves, need to decide if I want them at the top or in the bottom section.
   / My Lumber and Plywood Cart #8
I have the same problem and never knew of, or even thought of, a solution to it. I'm looking forward to see this all done and loaded up!!!
---------------------------- I'm looking forward to see this all done and loaded up!!!
Me too, but it is 74 degrees outside so the work on the cart will have to wait while I get outside stuff done.
Decided not to use the last set of shelves for now. I can install them later if needed. So it is finished for now. :thumbsup:
Added 1/2 inch EMT at a slant for the 4 foot wide sheets to lean against:
Moved the stuff from the wall onto the cart:
Still have a lot of room left on and in the shelves for lumber:
New/Unused Fuel Delivery Tank with Pump (A57453)
New/Unused Fuel...
Leer Camper Shell (A57454)
Leer Camper Shell...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2007 Jeep Wrangler Rubicon, VIN # 1J4GA39197L104496 (A57453)
2007 Jeep Wrangler...
Water/Sewer Milwaukee Tap Machine (A57453)
Water/Sewer...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
