my last minute project
/ my last minute project #1
KenGod
PA
CK2610HST
Since we have about 10" of snow on the way tomorrow, I thought I would make something up quick that I can push the snow with. i have been using my 5" rear Kioti blade but that thing is a pain to use. the blade is either to high or to low. Im going to make a set of feet for the rear blade one of these days and that will solve the rear blade issue.
anyways, I had a piece of stainless laying around for a few years now and had an idea. I went to my local metal shop had him make a few bends, then I had him cut me some pieces of 1" angle, brought it home and in about 2 hours it was done. Its hard to see in the pic, but behind the metal is a piece of 3/4 plywood.
Hope my effort pays off. I will find out tomorrow
ken
/ my last minute project #2
It'll be interesting to see how it works. May I suggest cutting off the sharp corners. They look like they'd hurt ha. I suspect the bottoms will not last long anyway.
Post pictures for us all to see!
I was going to get some auto door edge trim to put around the top of the metal, it is rather sharp, but it will work for now
/ my last minute project #4
All I use for snow is my rear blade and FEL. I like the combo alot. I take my toothbar off before using the fel for snow removal.
I like your new plow, hope it works for you. I know that wet snow and sufficient tractor speed will tend to make the rear blade wiggle in funny ways.
the rear blade problem is our 3/4 mile long driveway is gravel, if its to low it tears up BIG chunks of gravel and dirt, to high, no snow removal, as the tractor goes over highs and low in gravel so does the blade. When I make a set of feet for it then I can just drop the blade/feet on the gravel and let it ride, for now this was a good way to get some tinker time in
ken
/ my last minute project #6
Why not angle the device so it pushes snow off to one side? Wouldn't that be useful for a long driveway?
It is angled about 2" for now, after I see how it works I will start tweaking it here and there
/ my last minute project #8
First, thanks for posting.
Second, good luck.
It's always good to see alternative ways of doing things.
I'd love to find a simple cheap way to get a front blade set up.
I'm leaning towards mounting up a truck plow blade with hyd. angle.
I hope your set up works well.
Should definately work better than the bucket alone.
Joel
/ my last minute project #9
I'll be interested in hearing how it worked in the white stuff.
I solved most of my rear blade agravation by pulling it with the blade reversed so that the concave curve of the blade is away from the direction of motion. I also adjust the top link so that the blade has maximum tilt. I usually pull it so that means that I make the top link long to push the three point connection down. It doesn't dig up my gravel that way and does a decent job of pushing the snow off to the side when I angle it 30 or so degrees. Angling it causes one side to drop down so I have to use the adjustable side link to make it level again. I do that in the garage so that I'm sure that I have it level before I start out.
/ my last minute project #10
Thanks for the post. I have an idea for a plow for the FEL and would love to see pics of how yours works. How thick is the SS? I worry it looks a bit thin for pushing snow but the way it is mounted is interesting.
What I'm hoping to do is take a 6 foot John Deere snowplow that I got at an auction (I think it was from a Gator) and mod it to the FEL. But if yours works, it gives me other ideas for "wings" and so on.
I will watch this post for future developments....
/ my last minute project #11
Just from looking at the front it seems like the stainless steel would bend easily but from the rear looks quite beefy. Good luck with it, will be interesting to hear how it performs for you.
For the most part it worked great. I will need to put more of an angle to the blade. Right now it has a 2" offset, some snow rolls off the inside, but not much, I kept my rear blade offset to the inside and angle so it was catching what the blade left behind. Sry no pic's the wife wasnt going outside today, to cold.
A couple of tweaks and it will be perfect for my need. we only get plowable snow here 3-4 times a year so its not something that will get used weekly.
Ill take more pic's after I get time to modify the angle some
Ken
JOHN DEERE 9360R ARTICULATING TRACTOR (A64280)
JOHN DEERE 9360R...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
STORAGE FEES (A59912)
2006 Volvo VNM S/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM S/A...
