My First Real Tractor!
   / My First Real Tractor! #291
That stuff you see on the hood can just be water. Has this thing sat outside? my pipe has just a turn out on it and does not go very far and is undercut with a like 35 or 45 degree angle on it. If I don't put a bottle or something over the pipe and it stays out for awile it will get a small amount of blown rain in it and it will mist out like that for the first few hours of use. I aways put a water bottle with the top cut off over my pipe to avoid this. If youhave a rain proof flapper that may not be necessary.
I just opened the second picture to see this....a thought but probably not the source.
Like I said get some power source, and seafoam and put in there. power source even tells you that its safe to double up their dose. Seafoam is harmless I dump a half or whole can In my tank when I decide to use it. Maybe even try lucas injector cleaner, I know a lot of guys like that.
   / My First Real Tractor! #292
I noticed the angle when I suggested to turn the exhaust forward. And looked to be attached with a clamp so you can should be able to easily turn it down and point it forward if need be. No FEL. so there should be no reason not to except it may be a little long and point out the front to far. But then just unclamp it and shorten it. You can just put the angle on it and keep the pipe. If or when you nee to turn it up I have a extra flap your be welcome to.
:2cents:
   / My First Real Tractor! #293
I am pretty good about putting a bottle on it for storage. its habit now, just like disconnecting the solenoid wire for the ignorant thief. I do lots of turning close to trees and I worry I would catch it if I turned it forward. I thought about that. I also though about cutting it straight and putting a flapper on it. It works as is since I remember to put a water bottle on it now, I had one for the longest time, not sure where it went but was bent and already had a zip tie on it. I need to zip tie the current one, just the right wind lifts it up. Or a qt gator aid bottle works but the neck smaller and the weight of the bottle holds it better, even while on the trailer!!
Thanks for the offer though.
   / My First Real Tractor! #294
If you point it forward and then point the angle downward water not going to get into it. I live on 7 acres of woods. The only problem I have ever had wasn't getting to close to anything it was my Exhaust catching a low hanging branch, vines etc.. I've thought quite a few times to turn the exhaust. But with no problems with Blowby, Oil Bombs so just never had to. And I keep it out doors under a carport. I checked and I do have a almost New Top cap. The way I got it is the owners caught it on Branch and bent it and the Exhaust. Would not open all the way. It was easy to correct but they told me to leave it off since it was stored in a Barn always. And I told them what to do if they ever had to keep it outdoors. I cut a slice in a tennis ball for them. Squeeze and it slides right on...
   / My First Real Tractor! #295
Yea I know if I point mine foward and turn it down or even slightly to the side water can't get into it. Now I either park under a cover or throw a bottle on the pipe.
So I lucked out, traded my 5 foot bush hog I got for free for a four footer in even better shape straight up! I'll get some pics soon!
   / My First Real Tractor! #297
Good work. But if he needed a bigger hog it was probably just as good a deal for him! But sounds like u both happy!
Finally got to really work it hard for the first time. Ran the bush hog for about 4 hours today. Cuts great, works great! Couple of things I need some advice on:
1. The temp started climbing to around 215-220 after running for about 45 minutes. The stuff I am cutting is chest high and some places head high and very thick. Tractor is not bogging or lacking of power, but it is work. I shut it down and checked the radiator - FULL of crap from cutting. Put some mesh over the grill and I also forgot my "driver" side engine cover which will help next time. I brought a blower and cleaned and blew it out the best I could every 30 min or so but the little white things in the air literally kept caking on the radiator. I would shut it down for a minute, clean off what I could, then let it run around 1800 RPM for around 5 min and temp would drop down to about 175 and I'd go again. Kind of annoying, but I noticed the water in my radiator still needs to be flushed a few more times along with the radiator clogging up is probably the reason as it is obviously cooling correctly once clean again. Cleaned radiator with compressed air when I got back home and drained the dirty water. The block must just be full of all kinds of crud. Again, no oil at all - literally just muddy ditch water.
2. I developed a leak here on both sides. What would cause this, just old seals? Easy fix? It's odd, it seems like it almost stopped leaking as it's not getting any worse and I don't think it leaked anymore after the initial time....? Is there a vent or something that could be plugged possibly and made it "squirt" out there temporarily?
3. I only shifted the PTO from neutral to first gear at low RPM, everything is smooth. Can I engage the clutch (let it out) at any RPM with the PTO engaged? Or are you supposed to engage clutch at low RPM and then throttle up? Seems to work fine both ways just curious.
4. What RPM should I run at while bush hogging? I was around 2200-2400. The needle jumps around quite a bit - is this normal?
5. I did notice, the white smoke seems to be DECREASING after running it hard all day!
I think I am going to try and do a complete cooling system flush with some type of cleaner/product and get all of this crap out for good. Any recommendations?
   / My First Real Tractor! #300
#8 in attached is the vent for the transmission/hydraulics. Might want to check and make sure it is open. #s46 & 47 are the seals for the rockshaft but I doubt you would want to change them. HYDRAULIC_LIFT: Yanmar Tractor Parts
"3. I only shifted the PTO from neutral to first gear at low RPM, everything is smooth. Can I engage the clutch (let it out) at any RPM with the PTO engaged? Or are you supposed to engage clutch at low RPM and then throttle up? Seems to work fine both ways just curious." Either way, just engage slowly.
"4. What RPM should I run at while bush hogging? I was around 2200-2400. The needle jumps around quite a bit - is this normal?" Best cut at higher rpm. Whatever works best for you as long as not lugging your engine will be ok. Needle jumping is not unusual from my experiences.
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
