My First Real Tractor!
   / My First Real Tractor! #41
You can actually replace the PTO seals on many models without removing the PTO shaft. As described in the video- we removed the PTO assembly because the tractor we were working on had a wear collar and you have to remove the shaft to replace that. The 1700 does not have a wear collar which is good and bad. Good that you don't need to remove the PTO shaft to replace it. Bad because it does not have one and any wear that happens is to the PTO shaft itself.
On the 1700/2000 just remove the snap ring and run a drywall screw into the face of the seal and pull it out.
You guys are great, I cannot get over the support I have had from your company so far! Thank you to all the Forum members here as well for all of your help!
   / My First Real Tractor! #44
Kustrud
Sorry i miss spoke you were right I was wrong put foot in mouth thanks for the reply.
Kustrud
No worries man, I was really hoping you were wrong haha!
   / My First Real Tractor! #46
Luckily the 1700 and 2000 have wear coats practically everywhere else!
How often does the actual shaft get worn out? Really not wanting to dissemble that if I don't have to haha!
   / My First Real Tractor! #48
It would only rarely happen and probably only once in a tractors life to be that bad. And most likely would only occur after many thousands of hours of the pto running.
Got it, thanks! Well I took it down to our land to make some food plots and the temp guage I installed kept climbing to 220 after going down our road. So it shut it down and loaded it back on the trailer. Where do I start and what's the easiest way to fix this permanently? I was thinking order new radiator and water pump kit. We live too far away to get all the way down there and waste a trip.
I'll add that the radiator has a couple pin hole leaks and looks pretty rough.
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
STORAGE FEES (A51219)
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
