my dump cart
/ my dump cart #41
Nice build banditbooker. Would like a good dump trailer.
/ my dump cart #42
I have been trying to search on the internet, but can't find anything. I might not be using the correct search wording. But I was wondering if anyone has built a dump trailer using a scissor jack like the picture below.
Someone had a old 30ish Dodge truck for sale in my town recently, and the dump bed used a jack like the above, but of course it was much larger in size. I happen to have a very long acme threaded rod and nut,, you would probably have to custom make the jack so it would raise high enough. I thought the idea was a good one, and the setup I looked at on the truck looked like it was original/very old. You could even put a motor and gearbox on it if you wanted to.
/ my dump cart #43
Thanks to this thread, I've been researching building my own trailer when I stumbled across this.
Sure Trac |
$1,800
I was up to $500 with axles, rims, tires and springs and had not even figured in the steel yet.
I wanted to make my own because I wanted it small enough to pull behind the tractor and yet still street legal.
I don't know that I could beat this
/ my dump cart #44
The tires are perfect. They keep the deck low,looks really nice to load.
/ my dump cart #45
I bought a jack like that with an electric motor for my lil dump trailer, long story short the **** things have no power when there all the way down (physics) they gain lift power towards as they go up, anyhow I messed up the plastic gears inside don't know where I can get replacements I do have pics of my setup and have modified my pivot points to take some weight off the jack, so if anyone knows where I can get replacement gears for these Chinese junkers chirp in
2010 Sellick S-100 10,000lb Rough Terrain Straight Mast Forklift (A68183)
2010 Sellick S-100...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
CAT 320CL NEW Track Groups (A68134)
CAT 320CL NEW...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
