My BX25D is here!
   / My BX25D is here! #22
Congrats!!
Don't forget an aftermarket skid-plate if you will be working in the woods at all. I have the BXpanded one myself, and have been very happy.
I second the skid plates!!!!
   / My BX25D is here! #23
Frank,
I ordered a Type II Justrite from Amazon today,
congrats on the new machine!
anyone with experience (good or bad) mixing diesel and galvanized cans? i know you're not SUPPOSED to do it, but most people say they see no issues. may the ultra-low sulfur fuel is low enough not to create much issue?
i did find one mention of a negative experience HERE.
i'm using junk plastic cans. really want to move to metal but for the cost, not if they have issues. why don't they line the cans???
   / My BX25D is here! #24
Congratulations they really are nice little tractors. Most who have not actually used one underestimates them.
I agree on the skid plates, I like Bro Tek as the rear one can stay on with the MMM while BXpanded must be removed; our fan was broken while the MMM was attached, so don't depend on just it for protection.
I also added Hodge stabilizer bars, Bro Tek wheel spacers and BXpanded rear trailer hitch and on one an aftermarket grill guard from: Fab Works OEM | Kubota Attachments
Never, ever keep gas cans in the same area as diesel, wife and grandkids will eventually forget yellow and red; trust me.
   / My BX25D is here! #26
my new bx 2670 has fan protection on it from the factory
They did an upgrade a few years ago, but the ones I've seen are still too vulnerable for me, as mentioned an errant stick made it past my MMM which is usually considered to be good enough protection. I may just be overly cautious though and yours may well be fine.
   / My BX25D is here! #27
Like this?
It's standard on all the BX's I've seen, from 2011 to newer. There are some pretty large gaps still, as you can see.
   / My BX25D is here! #28
Ya...You have to look hard for some of the improvements over the years. Brake pedal changed, different tach, new seat, steering wheel etc. I added cab with lights, chains, and juice in the front tires but feel the Kubota people know how to build a good technological machine. A lot of after market parts are for guys who like to tinker.
   / My BX25D is here! #29
wow that hydro filter looks like it's placed in a prime spot to be ripped off or punctured. do any of the shields cover it up?
   / My BX25D is here! #30
Yes, thw Brotek and others cover all of that.
   / My BX25D is here! #31
Welcome!
I too, am a relatively new tractor owner, having purchased my BX25 last year.
I have a little over 200 hours on her now, and will give you my, unsolicited, opinion and advice.
My property is very steep and rocky. By steep, I mean we have a 200' drop over 800' distance. By rocky I mean, I have yet to pull up a bucket of earth without a boulder or large stone in it. Many places are pure boulders and stone.
Mods I have done, and would do again:
Skidplate
Wheel spacers
Toothbar
Thumb
Bro-tek stearing guard
3 point hitch
Mods I would not do again
Bro-tek tool box (it is a piece of PVC pipe with soft plastic caps on the ends. Torn off within 2 hours of install. Useless, and outrageously expensive at $50 for $3 worth of PVC)
Mods I think should be mandatory:
Fill the tires! At least the front. My front tires were forever going low or flat. My startig ritual included filling the front tires every time, and usually once or twice in a days work. I put tubes in, used slime and all other manner of tricks to try and get those little tires to stay full. Nothing worked. Since having the tires filled (and no, using great stuff is not the same), i could not be happier. I will be filling the rears when I can live without the tractor for a week or two.
Implements:
Bought a 4' box blade and used it a lot for gravel drive work and breaking up some land for planting. Great tool. I would not go larger than 4', as even that had me stopped in place a few times when the tines dig in.
Grapple: I just put on the SGC50 and I LOVE this thing. I have used it to pick up logs, grab debris, move thousands of board feet of old siding, rake leaves and underbrush, dig up small trees, the list goes on and one and I have only had it two weeks.
You will be pleasantly surprised by how much work this little guy can do. I saw you are in PA and I was going to invite you over to compare toys, but you are about 5 hours from me, so yeah....
   / My BX25D is here!
I've been eyeing the Piranha tooth bar....
   / My BX25D is here! #33
If you plan on digging with the loader, then you owe it to yourself to get one.
I took mine off for the winter, as I use the loader for snow removal.
Yesterday, I went to do a little digging and was confused as to why I was having such a hard time getting anything into the bucket. Aha! No toothbar. Put it on, and back to happy place. It really makes a huge difference.
   / My BX25D is here! #35
If you plan on digging with the loader, then you owe it to yourself to get one. I took mine off for the winter, as I use the loader for snow removal. Yesterday, I went to do a little digging and was confused as to why I was having such a hard time getting anything into the bucket. Aha! No toothbar. Put it on, and back to happy place. It really makes a huge difference.
Curious... does the Piranha not work as well for snow?
   / My BX25D is here! #36
I use the bucket, tilted down, to scrape down to blacktop. Since the toothbar is jagged, it does not lend itself to this use.
   / My BX25D is here! #37
I had a 32hp gas bobcat with a smooth bucket and a tooth bucket. I never used the smooth bucket. Most of my digging was in sod and tree roots. I just didn't have enough hp with a smooth bucket (one wide cut all at once). A tooth bucket has a smaller surface area and penetrates the cut with less force.
As a side benefit, those teeth worked as rakes/scarifiers when I was trying to spread sod/root filled dirt. I could do my rough finishing with the teeth, and do a final smooth with the back of the bucket. My 40hp tractor has enough hp and weight so the smooth bucket works for me. I still miss the teeth sometimes to spread out the "trash".
   / My BX25D is here! #38
Understand. I haven't moved snow yet with my BX so I was just thinking I would level the bucket and use the PTB bottom as the rub edge and the teeth would not gouge. Maybe that would not scrape enough?
   / My BX25D is here! #39
i ordered a "smooth version" of the toothbar to run in winter, for scraping ice off my driveway and saving the front edge of my bucket. works great!
   / My BX25D is here! #40
I have found, that in order to get down to blacktop, I have to angle the bucket down and put pressure on the leading edge. You can clear down to the last 1/4 inch or so without doing this, but my drive is very steep and curvy, and not all the cars are 4WD, so I have to get down to blacktop.
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2023 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2023 CATERPILLAR...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
