My 2320 Seat Fix
   / My 2320 Seat Fix #1
PCABE5
Platinum Member
Wisconsin
John Deere 4066R Cab and loader
An update on my seat experiment, I purchased two seat suspension springs from JD (M153100 for and X series standard suspension) that were roughly the same base diameter as the rubber under the seat. I pulled the rubber and put in the springs and used a fender washer and small bolt at the bottom of each spring as a keeper and the ride is day and night. Rides like a it should have when new. I had cut the tops of the springs a bit to make it level when I am sitting on it. Overall took about 15 min and $12.64 to make a decent ride.
It is a cheap fix and cheap experiment. I mowed a bit today to try it out and my back it thanking me.
   / My 2320 Seat Fix
You could be waiting quite awhile:) .
   / My 2320 Seat Fix #4
No pictures?...Shame on you:D
   / My 2320 Seat Fix
Well, darn me. I will get some on here tomorrow.
   / My 2320 Seat Fix
Here is a picture of the springs installed.
   / My 2320 Seat Fix
Forgot to mention and it did not show in the photo but I glued thin rubber disks under the seat (where the old rubber springs rode) so the springs did not contact the metal of the seat. So far so good, no problems but a smoother ride.
   / My 2320 Seat Fix #8
Great idea - just ordered mine and will let you know how it works out. Thanks for posting
Brad
   / My 2320 Seat Fix
Thank you. I have about 8hrs seat time on this setup so far, no complaints and everything is working just fine. Let us know how your setup works for you.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
Kubota M135GX (A57148)
Cushman Electric Cart (A55851)
Cushman Electric...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
