My 2008 L2800 won't start.
/ My 2008 L2800 won't start. #1
mrhar0958
Bethlehem, Pa
Kubota L2800, 2008
I have a 2008 L2800 tractor, with 415 hrs. It won't even try to start. I turn the ignition key to the right, the 2 red lights display, then the glow plugs light turns on, but when I continue to turn the key all the way to the right...nothing. It doesn't make any noises or even attempt to turn the motor. I made sure that the hyd. clutch peddle switch and the seat limit switches weren't stuck, they seem ok. Plenty of battery power. Can anyone please advise???:confused2:
/ My 2008 L2800 won't start. #3
Try with a set of jumper cables hooked to another running vehicle to be sure it isn't the battery first.
/ My 2008 L2800 won't start. #4
PTO lever engaged?
The battery was replaced in the fall. I think I'll try disconnecting it, clean up the terminals and re-connect it. If that doesn't work than I'll try jumping it. Thanks!!!
/ My 2008 L2800 won't start. #6
I'd vote for one of the safety switches, but check fuses too. You say the switches weren't stuck, but that doesn't mean they're working. I'd jump the switches one at a time.
Wow, great stuff you guys!!! I'll include jumping the switches in my troubleshooting. It sure seems like that may be the problem.
/ My 2008 L2800 won't start. #8
You did check to make sure the PTO lever was not engaged right?
/ My 2008 L2800 won't start. #9
If it's a HST, rock the foot pedal back and forth...
WAHOO, I got my tractor running. I jumped out the switches but that didn't fix the problem. There is a plug connection for the starter hot wire located at the battery terminal...I reseated the plug and this fixed my problem. The battery wasn't secured properly by the supplied bracket and it must have bounced around enough to yank on the plug a little. Apparently a self inflicted wound from when I changed the battery in the fall.
Thanks for all of your suggestions!!!
2020 FREIGHTLINER CASCAIDA 123 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2020 FREIGHTLINER...
2025 LandHonor LHR-ME380X1 Stand-On Track Loader Skid Steer (A60352)
2025 LandHonor...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2025 Swict 60in Bucket Skid Steer Attachment (A61567)
2025 Swict 60in...
2012 Great Dane 53ft. T/A Reefer Trailer (A61568)
2012 Great Dane...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
