MX5200 Engine Problem
/ MX5200 Engine Problem
There is a jeep video on youtube that would show what I had going on !!!
/ MX5200 Engine Problem #12
Several years ago, I had to try the old "plug the air intake" trick on my little BX for some reason involving operator stupidity. Even that little 3 cyl. running at idle was going to ingest anything that got in the intake. It never did shut down using that approach and it finally shut off when I found and reconnected the loose wire to the shutoff solenoid.
But fair warning to anyone thinking of trying it on a larger engine that's wound up: you wouldn't believe the suction that's involved. Think jet engine intake, not lawn mower engine!
Rabcon, sorry to hear of your misadventure. Thankfully, it sounds like the dealer and Kubota will take care of you. Keep us posted.
/ MX5200 Engine Problem #13
I had a similar situation last winter while moving snow. My crankcase vent froze up and the engine revved a bit and then spit the dipstick about 15 ft into a snowbank. Fortunately I was able to shut it down prior to runaway. There was no other damage to my MX5100, other than the skid mark on the seat!
Hope your dealer can get you fixed up Pronto.
/ MX5200 Engine Problem #14
sounds like the tractor had a major problem that caused the engine to blow up.
It's going in the shop tomarrow. But Yes the Dealer is one of the better ones when it comes to costomer service !! Dragon's Farm Equip. in Mooers NY . A Great Dealership to have so close to home .!!!! Service means a LOT !!!!
/ MX5200 Engine Problem #16
You should get a new engine. Went through something similar many years ago on a Deutz engine appication. We had hydraulic pumps with defective seals that allowed hydraulic oil to pass into the crankcase. Eventually it got so high it foamed, was drawn through the crankcase ventilation into the intake manifold. Gradually that oil took over and the engines went out of control. I talked to one owner who was shaking from the experience. When he realized something was wrong and he couldn't stop the engine, he dismounted and raised the hood. That multiplied the perceived noise - he said he took off running because he knew it was going to explode. Like yours, however, it died from being choked to death. We gave all 5 customer's to whom this happened new engines - it was the right thing to do. And we immediately redesigned the hydraulic pump drive so this could never again happen.
Well I stopped at the Dealer this morning, and the problem was that the engine venting system was froze up. Which caused the engine to force the engine oil into the intake just befor the torbo in the intake tube. Which caused the engine to runaway burning the engine oil. So now the dealer is in contact with Kubota and trying to get a complete replacement motor. I will update when I get more info . There is a update kit on some models to stop this isue but I was told this is the first MX5200 to have the isue.
/ MX5200 Engine Problem #18
Good luck to you,I hope all turns out well.
/ MX5200 Engine Problem #19
Good to hear your dealer is on top of the problem! They're your best ally with the corporate negotiations.
AKfish
/ MX5200 Engine Problem #20
What does the update kit do to stop this problem?
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
CATERPILLAR 279D3 SKID STEER (A62129)
CATERPILLAR 279D3...
(4) Dura Trench Drain Grates (A60463)
(4) Dura Trench...
TANK MANIFOLD (A58216)
