MX5100 shredding
/ MX5100 shredding #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
for those of you wondering if a mx5100 can handle a 3pt 6ft shredder in heavy shredding the answer is yes.i run in low at 1800 to 2000rpms.an the shredder goes through anything i ask it to.you need to run at 2000rpms for heavy stuff an drive slow.
/ MX5100 shredding #2
I sure believe it, I ran a Land Pride RCR2672 on our L5030 through the same stuff as our M8540 with a Woods DS1260 and the MX seems a bit more robust. I ran 2250 I think with the 8540 and about 2600 or so with the 5030.
/ MX5100 shredding
i dont like the blades spinning at 540 because i dont know what i could hitt.but its a great tractor for everything i ask of it.
/ MX5100 shredding #4
I also would think so. I have two smaller Kubotas that'll shred everything the tractor will push over. :D
/ MX5100 shredding #5
I get a better cut and smaller pieces running at PTO speed; often cut saplings, brush etc. and the cut looks cleaner on grasses.
/ MX5100 shredding #6
I use an rcf2772 with mine. I always run at or near pto speed for a better cut and higher ground speed. Usually cut in 5th or 6th gear depending on conditions.
The mx5100 has plenty of power for a bigger cutter but I settled on a stout 6ft model due to cost.
/ MX5100 shredding #7
Photos!
/ MX5100 shredding
i have 1 bad falt i never take the camera with me.
