MX5100 shredding
/ MX5100 shredding #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
for those of you wondering if a mx5100 can handle a 3pt 6ft shredder in heavy shredding the answer is yes.i run in low at 1800 to 2000rpms.an the shredder goes through anything i ask it to.you need to run at 2000rpms for heavy stuff an drive slow.
/ MX5100 shredding #2
I sure believe it, I ran a Land Pride RCR2672 on our L5030 through the same stuff as our M8540 with a Woods DS1260 and the MX seems a bit more robust. I ran 2250 I think with the 8540 and about 2600 or so with the 5030.
/ MX5100 shredding
i dont like the blades spinning at 540 because i dont know what i could hitt.but its a great tractor for everything i ask of it.
/ MX5100 shredding #4
I also would think so. I have two smaller Kubotas that'll shred everything the tractor will push over. :D
/ MX5100 shredding #5
I get a better cut and smaller pieces running at PTO speed; often cut saplings, brush etc. and the cut looks cleaner on grasses.
/ MX5100 shredding #6
I use an rcf2772 with mine. I always run at or near pto speed for a better cut and higher ground speed. Usually cut in 5th or 6th gear depending on conditions.
The mx5100 has plenty of power for a bigger cutter but I settled on a stout 6ft model due to cost.
/ MX5100 shredding #7
Photos!
/ MX5100 shredding
i have 1 bad falt i never take the camera with me.
2014 WINPOWER DR2014-AAMTJ GENERATOR (A59910)
2014 WINPOWER...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63118)
2019 Takeuchi TL8...
2023 Case TV450B (A62177)
2023 Case TV450B...
2013 WESTERN STAR 4900 SB MIDROOF SLEEPER (A63569)
2013 WESTERN STAR...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
