MX-5 Gear Box
/ MX-5 Gear Box #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
I bought a used MX-5 mower and do not have a manual. Can anyone tell me what the proper fill level is in the gear box. When I pull the filler plug there is about 1/2" showing on the stick-as the stick is about 2 or 3" long, that leaves a lot of potential fill capacity. Also 80/90 gear lube???
Thx
/ MX-5 Gear Box #2
Normal fill is center line of the input shaft. 80/90wt is fine.
/ MX-5 Gear Box #3
There are two "lines" at the bottom of the flill plugs "stick" that sticks down into the gearbox. You fill till the oil is between those to line with the fillplug/dipstick screwed in fully. Reading from my Deere manual for my MX 6 it states; " Install dipstick/vent and screw in fully, then remove,oil should be between lines. Add oil as nessesary."
Don't over fill as this won't leave enough space for expansion of the oil as it heats up and you'll have a "gusher" on your tractor. Good luck with the MX5.
/ MX-5 Gear Box
Thx guys-kind of assumed the double line was a "low/Max" point but you now what they say about "ASSuming"!
/ MX-5 Gear Box
Thx John
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
INOP/NON-RUNING Genie GS3232 Scissor Lift (A65579)
INOP/NON-RUNING...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
