Must Have Shop Items
   / Must Have Shop Items #251
trailering - DOT regs 1 at front 1 at back and 1 every 10' Equipment minimum 4 1 every corner + more for attached implements
pulling - 300' of chain is safer than 300' of cable if it breaks
   / Must Have Shop Items #252
Most of my chains fit in a steel box on the truck. The 1/2"grade70 chains are only brought out when the need arises. By the time I chain down two tractors and a skid steer it takes six 10 footers plus what ever chains needed for the attachments. The shop gets a bit small when things get put into the shop for the winter.
   / Must Have Shop Items #253
Part of my problem is the $32,000 need just to bring in power. The other part of the problem is the $48,000 just to put up an insolated building with a roof strong enough to support 160 pounds per square foot to support our snow loads.
Yeiks... are you off grid
   / Must Have Shop Items #255
Three Phase Power???
   / Must Have Shop Items #256
I just dug thru my paperwork to get accurate. Cost me $42.73 per square foot to build my shop. It's all weather and just as comfortable inside as my house. Construction costs are shocking.
I have great sympathy for anyone that doesn't have a shop but has the need for one. I'd be lost without mine.
   / Must Have Shop Items #257
I paid 36.500 for my 30x52, of course that was 11 years ago. 1020 sq. feet of it is wired, sealed with 1/4" plywood and walls and ceiling insulated with R30. 12 foot wide lean to sheds comprise each side. It has a 30x30 main shop clear span with a 12 x10 on one side for bathroom and storage area and mandoor. Complete with insulated garage doors with electric openers. I had it built before I built my house.
A shop or mancave is important to have especially during our now self quarantine due to the Covid-19 pandemic.
I have it stocked with several compressors, table saw, multiple grinders, porta-a-bandsaw, 5 battery powered drills, blowers, skilsaw, sabre saw and light, 120v 1/2" drill motor, 250 amp stick welding machine, MIG welder, FCAW welder, lots of storage shelving and a work table. Many other small tools and wrenches with 3/8 to 3/4" drive sockets to work any item on my tractors. I also have several air tools including impact drivers, die grinders, right angle drills and air chisels. A heavy impact driver is a must have for removing rusted bolts.
   / Must Have Shop Items #259
Or just far from it? Terry's nabe is pretty built up with infrastructure by likely comparison. Does Eric actually do things indoors? I didn't think so at his young age. :) (You go, Man!)
Not many home shops need 3Ph power. 1 ph equipment doesn't cost as much more as it's always harder to find. Machines more than 2 hp may be a luxury like driving a Minmog to work. Could be a big upgrade to full shop from just a workbench. (Is there serious woodworking planned that we haven't heard about?)
btw, I took DRO's back off one lathe and haven't finished installing 3-sxis on the small 'locator' mill. I made all the scale mounts and transducer brackets on them without using DROs and haven't felt the need for them yet. (prototypes vs production) Hand-wheel spinning may become a lost art, but we practitioners know how to deal with backlash and can hold tolerance with the best. If you want CNC and/or DROs IMO they're not necessary for one-off job.
Make chips, boys! (Sawdust is just as good, any day!)
   / Must Have Shop Items #260
Sure, there's definitely fun and craft doing it old skool. I respect that, but...you could do complex division on paper too, but it's hella easier and faster with a calculator. Same logic with dro's, and you could get chi-com ones pretty cheap now, they work just as good.
A rotary phase converter is a whole lot cheaper than getting 3ph into a home, a vfd even way more cheaper than that.
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2022 John Deere Z930M (A57148)
2022 John Deere...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
